OEM high beam...switch to yellow fog light only....
hey does any onw know how to make the High beam just turn on without turning on the low beams, i was thinking of puttin some yellow fog blubs for a fog light but my low beam always have to be on tho...
Im pretty sure you can just wire up fog lights. Install them into your current headlight setup (or at least I would think you could just drill a hole in the assembly and install the bulbs) and wire it to a switch that you'd install on your dash.
Luminics I believe is the yellow bulb people use or PIAA
and easiest to do would be wire them up (I would assume) to the grounds that the corners are on, fog lights turn on with the corner lights
lol no no,
wire the ground wire of the high beams to your corners, then when you turn on your corners the high beam will be on (or should be )
they won't stay on unless you change the wiring or have low beams on
92ehatch
10
Nov 22, 2005 11:36 PM
