catalytic converter question
Do they sell catalytic converters for a 97 accord that have an o2 sensor port? If not, would it be a good idea to keep the stock converter or just to go ahead and get a new one? What would be my best bet? THANKS
If the CAT is made for the car it should have the secondary O2 sensor port in it, even the aftermarket units.
What made you decide to replace your CAT?
Well, My plan was to replace the exhaust system only but when I saw how badly corroded the CAT was I decided that I might as well replace it too. For now I think I'm going to keep the stock CAT that I took off but the only problem is the bolts are so corroded on that I can't get them off unless I weld cut them. I can't even count the number of times I've sprayed PB on the bolts and let them sit. I guess I will keep trying. bah
