92 DA W/ 5 LUG SWAP....wilwoods and nsx....
Old May 7, 2007 | 04:28 PM
92integra-R's Avatar
Default 92 DA W/ 5 LUG SWAP....wilwoods and nsx....
i had to put a spacer in the rear to clear the caliper. now i can only catch a few threads on each stud. i wanna buy some new wheels for this setup, that i wont have to use spacers with. prefer to get 17"x 7" or 17" x 8" if i could fit them. those wheels that are on it now are off a older TL.
what offset sould i look for? and are they 5/100?
Old May 7, 2007 | 04:33 PM
Mt3c's Avatar
Default Re: 92 DA W/ 5 LUG SWAP....wilwoods and nsx.... (92integra-R)
5x114.3 don't know what offset you should look for.
how about getting extended wheel studs?
Old May 7, 2007 | 04:36 PM
Default Re: 92 DA W/ 5 LUG SWAP....wilwoods and nsx.... (Mt3c)
yeah, i plan on using extended wheel studs. but the wheel will still need a spacer...
Old May 7, 2007 | 04:50 PM
Pee Wee's Avatar
but with the extended wheel studs you could use those rims
Old May 7, 2007 | 04:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 92 DA W/ 5 LUG SWAP....wilwoods and nsx.... (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">but with the extended wheel studs you could use those rims</TD></TR></TABLE>
but those rims are ghey
Yeah some new wheels would look sweet. What is the offset and width on those TL's?
Old May 7, 2007 | 05:05 PM
yeah, but i dont even wanna use the spacers. i want to buy something in the rays family. the TL rims are 6.5" wide... not sure of the offset either. you think its stamped some where?
Old May 7, 2007 | 05:27 PM
Community Builder
Yeah it should say something like ET +__ (whatever), either around the outer edge of the rim, or it might be on the back of the spokes. Yeah I see why the spacers were needed, being only 17x6.5 (retarded size).
Old May 7, 2007 | 06:27 PM
Sumslapper's Avatar
Year 3030
Default Re: 92 DA W/ 5 LUG SWAP....wilwoods and nsx.... (PatrickGSR94)
get new wheels, spacers are bad news prone to problems. my work doesnt even touch a car if it has spacers on it. or just get a smaller brake setup? why do you need so much stopping power? do you run 12's or something? track use?
edit: read the sig some im guessing you put down good numbers with that setup. i would just get a full wilwood or choice of brand and sell the nsx calipers
Old May 11, 2007 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it should say something like ET +__ (whatever), either around the outer edge of the rim, or it might be on the back of the spokes. Yeah I see why the spacers were needed, being only 17x6.5 (retarded size).</TD></TR></TABLE>
they are 16" x 6'5"...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">get new wheels, spacers are bad news prone to problems. my work doesnt even touch a car if it has spacers on it. or just get a smaller brake setup? why do you need so much stopping power? do you run 12's or something? track use?
edit: read the sig some im guessing you put down good numbers with that setup. i would just get a full wilwood or choice of brand and sell the nsx calipers</TD></TR></TABLE>
well i plan on making at least 400 (at the least). and i wanted the car to be able to go scca, or at least be ready for somthing like that. the reason for NO wilwoods in the back, is because you lose your e-brake... and i wanted to keep it. i just want to buy some 17's that fit....
Old May 11, 2007 | 01:38 PM
Community Builder
Are you kidding?? Wilwood makes a brake setup for Hondas but doesn't provide for the e-brake??? What the hell kind of retarded setup is that
Old Oct 27, 2008 | 08:11 PM
produca2's Avatar
Default Re: (PatrickGSR94)
reference...
Midori Green
15
Jan 1, 2008 10:39 PM
SoCal EJ1
Apr 7, 2007 07:08 AM
mikeunreal2
Apr 16, 2006 02:55 AM
BLUE EH3
Suspension & Brakes
19
Oct 4, 2005 09:34 AM
gakkuken
21
Jan 10, 2005 02:28 PM
