Need clutch help !! (decisions decisions!!!)
Old May 7, 2007 | 03:07 PM
LunchboxZT's Avatar
Default Need clutch help !! (decisions decisions!!!)
The FAQ at the top of the page doesn't appear to have any info on clutches (I'll be honest, I didn't search thoroughly, but a CTRL+F warrented me nothing)
So I'm asking this question.
My clutch went out and I'm looking to replace it, right now she's mostly bolt ons T1R exhaust, JDM header, CAI. etc.
When it comes to clutch brands and pucks and organics and all that, I have no idea what to choose, or whats best for my setup, I read all about the exeddys, and it sounds like an exeddy stage II is good for me, but what other brands are out there? how do I compare clutches??
I autoX and ocasionally track her, she hasn't been to the drag strip, but I was thinking with a new strong clutch I'd try to hone my skills in.
I want something thats practical, I do a lot of city driving, but I also want it to be strong and reliable, with a bit stiffer than stock feel.
Also, do you think I should replace the flywheel while I'm at it? I've got the extra cash.
Old May 7, 2007 | 03:15 PM
PrinceAli132's Avatar
Default Re: Need clutch help !! (LunchboxZT)
Check out the ACT HDSS.
IMO, I would change out the stock flywheel with a lighter one while you have everything apart.
Ali
Old May 7, 2007 | 03:52 PM
98 ITR's Avatar
I'm in the same boat as you right now, but I'm coming from an ACT 6-Puck disk. To be honest, I don't like it. It's a bit much for any sort of DD task too. I'm thinking of going the Exedy stage 1 organic route, but we'll see.
I don't know man, your clutch selection really impacts the way your car drives and feels. Don't shortchange yourself, but alot of the Stage II+ clutches are a little overkill for a stock R motor IMO.
Just my $0.02
Old May 7, 2007 | 06:15 PM
ithrowpoop's Avatar
Default Re: (98 ITR)
i just recently replaced my clutch. i had an exedy organic go bad too early. went back to stock. car has mugen intake and spoon header. it is mostly a track/ auto x car so i will see how it holds up.
Old May 7, 2007 | 07:07 PM
RagingAngel's Avatar
https://honda-tech.com/zero...age=1
for your flywheel.
I ordered 4 from them (or was it 3?) and they all came nicely boxed up and always arrived on time.
The flywheel will already be enough to change how your car reacts and feels. I like the Exedy stage II 3 puck THICK disc. There's a bit of shudder and it engages a bit quick...other than that, if you want easy driveability, just go back to stock and you and your wallet will be happy.
Old May 7, 2007 | 07:09 PM
itralex's Avatar
Default Re: Need clutch help !! (RagingAngel)
I like the Exedy Stage 1 organic
the pedal feel is stiffer than stock and I think its plenty for a stock ITR with bolt ons.
I'm using this clutch in my motor which makes 162 ft/lb of tq and its held up fine for the past 2 years
Old May 7, 2007 | 07:34 PM
R-box's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Check out the ACT HDSS.
Ali</TD></TR></TABLE>
ACT has some decent clutch kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 ITR &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the same boat as you right now, but I'm coming from an ACT 6-Puck disk. To be honest, I don't like it. It's a bit much for any sort of DD task too. I'm thinking of going the Exedy stage 1 organic route, but we'll see.
Just my $0.02</TD></TR></TABLE>
Right now, my R has the ACT Heavy Duty Pressure Plate with the Performance Street Disc and a lighter flywheel (but I can't remember which - previous owner put it on the car) and I really like it! I never knew the stock R clutch feel, but when I felt it in a friend's R, I hated it. This clutch setup is great - feels stiffer than stock, but it's not too stiff/an ultimate workout. I have yet to auto-x it, yet though, as I'm fixing other problems on the car, but yeah. Oh yeah, I've also put +40k miles on it.
Old May 8, 2007 | 06:08 AM
LunchboxZT's Avatar
Default Re: (R-box)
Okay, so if I went with a Fidanza Aluminum Flywheel and Exeddy Organic Stage I - would that be a decent setup? Also, is the wear life on an aluminum flywheel shorter than stock? and is the Exeddy expected to hold up as long as stock?
thanks guys, I'll be ordering my parts this afternoon.
Oh, anyone have a recommended shop to buy an exedy clutch?
Old May 8, 2007 | 06:20 AM
tartje's Avatar
Default Re: (LunchboxZT)
the stock clutch on mine held up to even the harshest punishment on track with 195whp and 128wtq going through it, personally i don't see the need for anything else on a lesser setup
Old May 8, 2007 | 06:54 AM
walker111's Avatar
Default Re: (tartje)
excedy
Old May 8, 2007 | 07:07 AM
EG6-DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">the stock clutch on mine held up to even the harshest punishment on track with 195whp and 128wtq going through it, personally i don't see the need for anything else on a lesser setup </TD></TR></TABLE>
I am close to this, I have around 192 whp and am still on the stock clutch. It's holding great and I'm not about to change it. Though the Excedy stage 1is a pretty good clutch, its basically stock. I would also look into the Excedy flywheel.
PM BlueR, he will get you a clutch and flywheel deal. He is awesome to deal with. I'm sure everyone on here will give him
Old May 8, 2007 | 11:07 AM
LunchboxZT's Avatar
Default Re: (EG6-DC2)
Just bought my Exedy Stage I Organic Clutch + Chromoly flywheel from BlueR.
Old May 8, 2007 | 11:28 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">Just bought my Exedy Stage I Organic Clutch + Chromoly flywheel from BlueR.
You will not look back on this decision, this i assure you. I have the same set-up in the Geezer and wish it was in the R too. Oh gosh... did i just say that? What i mean is Marc, i don't... neeed.... i mean.... ummm.... **** just send me the bill!
Old May 8, 2007 | 11:38 AM
EG6-DC2's Avatar
Awesome
Marc is a great guy. More like the devil, who makes you spend your money.
Old May 8, 2007 | 11:40 AM
jordanitr's Avatar
I just got my ACT HDSS put in and I love it, grabs very well and way better than stock.
Old May 8, 2007 | 01:39 PM
white rocket's Avatar
Default Re: Need clutch help !! (jordanitr)
ACT HDSS with a 7.5lb Fidanza aluminum FW. I'm more than happy with it . Great modulation and feel for DDing and also great grab when you get on it.
Old May 8, 2007 | 02:05 PM
nholmes's Avatar
I'm running the same and I bought them from BlueR.
Old May 8, 2007 | 06:14 PM
R.Kelley's Avatar
Action 1MS its a six puck, i just ordered it today, ill be running it with a ACT prolite wheel
i run an action 2MS in my EK with a action aluminum wheel, and it sucks to DD with
Boots
Honda S2000
Apr 7, 2009 10:40 AM
93CivNewB18
Jan 8, 2009 02:06 PM
blueturbo4door
Nov 17, 2003 03:07 AM
R0902
Sep 1, 2002 09:24 AM
CanadaCivicSIR
Nov 19, 2001 02:48 AM
