Help with Clutch
New User
Help with Clutch
Well it is time for a new clutch and I was wondering what the best clutch is for my application. SOHC vtec, goes in right away for the supercharger. I want a clutch that can handle up to 300 hp no problem and is streetable since this car is my daily driver. I am also going with a lightweight flywheel, but I need a good clutch that isn't going to wear out fast.
Thanks
Thanks
Re: Help with Clutch (CanadaCivicSIR)
I would look into ACT, Clutchmasters and Exedy. ACT is rebuilt, Exedy is a new unit, and dunno about CM. All these manufacturers produce a specific clutch for the kind of driving or racing you do. You also have to factor in pedal feel (engagement). As for a personal recommendation, sorry I can't help you out, but these were the main clutches recommended in most the clutch posts I read. Did you try using the search function? Good luck
New User
Re: Help with Clutch (Hibid)
from what i read, clutchnet has a very stock like pedal feel. act, i know for a fact, has a pretty stiff pedal feel. so in my opinion, clutchnet would be good for daily driving
99V-unit
03-26-2008 04:51 PM
