4 lug to 5 lug?
before i start, i did search honda tech and only found sales. i was wondering what all do i need to switch my 2000 civic si from 4 lug to 5 lug? any diy threads? thanks in advance and sorry for the newbish question.
i wana rock these
yeah another newb question what size are these wheels? 15 or 16?
i wana rock these
Those are 15's.
You need to buy a 5blug conversion from a ctr or an ITR.
They can be found here in the marketplace or on ebay/craigslist.
Most conversions with wheels can be had for ~$1000
here is a write up. it is on an eg but its pretty much the way you have to do yours. good luck!
http://www.jdmvtec.com/
IMO.. thats alot of money and work for a set of rims... but i guess then you could say you have a "5 lug conversion"... but im sure i could find another set of rims to set my fancy and save myself a G
Not to mention M4D TYT3 JDM Y0000...
Lol but yea if you buy the conversion thats basically everything you need i think the cables for the ebrake need to be changed out so i think guys are using Gsr e-brake cables for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning »</TD></TR><TR><TD CLASS="quote">it's not just a set of rims
wider wheel choice
bigger and better brakes front and rear</TD></TR></TABLE>
Yep.
Plus the 15" itr gunmetal and the 16" ctr white wheels are two of my favorite wheel setups.
The itr 15" is one of the few 15" wheels I actually like on ek's.
wider wheel choice
Yep.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeeJayy »</TD></TR><TR><TD CLASS="quote">are the brakes really any bigger then my stock si setup??
and thanks to everyone.. i appreciate it
They're a little bigger. But what's more important is the brake master cylinder and the pistons.
Yes, it's one of the best brake setups you can get. bang/buck.
</TD></TR></TABLE>They're a little bigger. But what's more important is the brake master cylinder and the pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">the fake lip killed that car
yeah that rear lip doesn't fit all too well. And the paint doesn't look like it matches well either.
Still a dope car though.
</TD></TR></TABLE>yeah that rear lip doesn't fit all too well. And the paint doesn't look like it matches well either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">here is a write up. it is on an eg but its pretty much the way you have to do yours. good luck!
http://www.jdmvtec.com/</TD></TR></TABLE>
This is the one im using.
that coupe looks just like mine except mine's MR, your e-brake cables will work fine, mine's an EX and i had to buy Si ones, also, needed some bushings for the rear LCA's from an EG , stainless steel lines would help too, also your prop valve will work fine, i was recommended to upgrade the master cylinder and break booster, but you dont need it right away, just a plus to have
the breaking is definately better and once you get it on you will most likely need an alignment
tvn521
Suspension & Brakes
22
Oct 4, 2007 08:20 AM
