drivers headlight not working...not a burnt bulb
Old May 7, 2007 | 02:18 PM
the.hamburglar's Avatar
Default drivers headlight not working...not a burnt bulb
ok so my low beam drivers headlight is not working all the time. it seems to come only when the front end of the car is jacked up which is stupid. however the highbeam works all the time. i tried switching bulbs and the same thing happens. so there is definatly a connection issue. where shouldi start? it doesnt make sense to me whey the low beam only sometimes comes on and the highbeams will always come on. i have a 94 del sol. thanks
Old May 7, 2007 | 03:13 PM
MJ0LNIR's Avatar
Default Re: drivers headlight not working...not a burnt bulb (the.hamburglar)
You probably need to level off your headlight fluid.
Old May 7, 2007 | 03:14 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: drivers headlight not working...not a burnt bulb (dr92cx)
Sounds like that headlight might not be grounded. Check the wiring look for anything that's out of place.
Old May 7, 2007 | 03:51 PM
Dilly's Avatar
Default Re: drivers headlight not working...not a burnt bulb (ek forever guy)
check your low beam relay as well.
Old May 7, 2007 | 08:30 PM
Default Re: drivers headlight not working...not a burnt bulb (diLLy)
hmmm, how do i check the low beam relay...that might be it. i have my boost gauge and wideband hooked up to the low beam fuse under the steering wheel...ill have to take a look. thanks
Old May 7, 2007 | 08:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like that headlight might not be grounded. Check the wiring look for anything that's out of place.</TD></TR></TABLE>
ya checked that. everything seems to be in place.
Old May 8, 2007 | 03:00 PM
does someone have a wiring diagram?
reddysol
Sep 23, 2007 10:42 PM
darkfx
Jun 25, 2005 09:48 PM
civic_hatchy
Nov 26, 2004 01:08 PM
goofyej6
Oct 19, 2004 06:41 AM
accord ex
Mar 13, 2003 05:55 PM
