hydro tran, cable tran... dust ring question
Old May 7, 2007 | 01:24 PM
JDM*addiction's Avatar
Default hydro tran, cable tran... dust ring question
this is kind of a 2 part question...
to the best of my knowledge after searching and reading for about 2-3 days straight what i understand it as is that what axles you use is based basically on what drivers side tranny seal you are using. ie
if you have a ys1 cable tranny you should be using 90-93 ls integra axles, and 90-93 LS intermediate shaft with the 90-93 drivers side tranny seal
AND if you are using a gsr hydro tranny you should be using 94+ gsr axles with 94+ gsr intermediate shaft because it has a 94+ gsr drivers side trans seal.
CORRECT?
and the real question is.. if the 94+ gsr hydro axles are longer why is it that you do not have to remove the dust shield on in the knuckle? (every one i hear from that is using 94+ gsr axles with their hydro tran that are using said corresponding axles parts say they did not remove their dust shield and there was no binding?
-and is it also correct that you can use 94+gsr axles in a cable trans as long as you use 94+ gsr intermediate shaft with 94+ gsr tranny seal
Old May 7, 2007 | 03:00 PM
Crx Jimmy's Avatar
Default Re: hydro tran, cable tran... dust ring question (X EF*Killa X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X EF*Killa X &raquo;</TD></TR><TR><TD CLASS="quote">
-and is it also correct that you can use 94+gsr axles in a cable trans as long as you use 94+ gsr intermediate shaft with 94+ gsr tranny seal</TD></TR></TABLE>
yes correct ^^
Old May 7, 2007 | 03:34 PM
Janos Lin's Avatar
Default Re: hydro tran, cable tran... dust ring question (Crx Jimmy)
Yep u can. I've got a J1 Tranny, 94+ GSR shaft and a set of hybrid axles from Raxles. Had to install the 94+ driver's side seal. Didnt have to mess with any dust ring and it works like a charm. You just need to match the seal to the shaft that you have and the axles to your shaft.
Janos
Old May 7, 2007 | 04:43 PM
Default Re: hydro tran, cable tran... dust ring question (Janos Lin)
cool deal. i think that's the best way to put it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Janos Lin &raquo;</TD></TR><TR><TD CLASS="quote"> You just need to match the seal to the shaft that you have and the axles to your shaft.
Janos</TD></TR></TABLE>
but why is it that you usually take out the dust ring when using a 90-93 axle.. ? i mean they are shorter
Old May 8, 2007 | 09:56 PM
dust ring question any one?
Old May 9, 2007 | 11:05 AM
Janos Lin's Avatar
Could be because the axle is bigger externally and touches the dust ring which messes things up because that part doesn't rotate with the axle. Didnt have a problem with mine.
Janos
lilpastrana
Sep 6, 2007 07:30 AM
civiconfire
Feb 27, 2007 07:29 PM
paulzy
Oct 4, 2006 12:19 AM
Charlie Moua
Sep 14, 2003 01:06 AM
Si-Yaaa!
May 10, 2003 05:02 PM
