Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Check gas cap error on display
Old May 7, 2007 | 12:38 PM
kloscivicsi's Avatar
Default Check gas cap error on display
got the 06 si and the message "check gas cap" on the odo display. This came on after 300 miles since i filled when i stated it up. I since filled up and re tightened the cap. Is there any way to reset this i held the reset button didnt do nothing. Anyone experience this.
Old May 7, 2007 | 12:49 PM
AlabasterSI's Avatar
Default Re: Check gas cap error on display (kloscivicsi)
Its kinda of funny you brought this up cause mine just came on today also. It says in the manual to take cap off and re tighten but it will take a couple trips back and forth to were ever for the computer to readjust for the message to go away.
Old May 7, 2007 | 12:56 PM
TRE_'s Avatar
Default Re: Check gas cap error on display (AlabasterSI)
The notification should reset itself and go away shortly.
Just make sure you always correctly tighten the cap so it doesnt happen again
Old May 7, 2007 | 12:58 PM
FG Deux's Avatar
You can simply disconnect your battery for 10 minutes. You're deck will keep the presets after you enter you anti-theft code. I had this same error but i was tired of looking at so i just unhooked my battery.
Old May 7, 2007 | 01:13 PM
Default Re: (FG Deux)
filled the gas drove 51 miles still on. guess ill have to dc my batt. too bad there isnt a way to reset it
Old May 7, 2007 | 01:19 PM
IT GUY's Avatar
Default Re: Check gas cap error on display (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">The notification should reset itself and go away shortly.
Just make sure you always correctly tighten the cap so it doesnt happen again </TD></TR></TABLE>
X2 listen for 3 clicks
Old May 8, 2007 | 05:00 AM
Michael Bolton's Avatar
Default Re: Check gas cap error on display (IT GUY)
same thing happened to me 2 or 3 weeks ago. I also re-tightend the gas cap but i still got the check gas cap message. I looked in the book and all you have to do is press the SEL/RESET button on the left of the steering wheel. Everytime the you turn the car off and then on the message will appear. It should stop within a day.
Old May 8, 2007 | 05:06 AM
blue rocket's Avatar
Default Re: Check gas cap error on display (Michael Bolton)
mine took 2 weeks for it to go away...just be patient.
Old May 8, 2007 | 05:34 AM
06BlackSi #45's Avatar
Default Re: Check gas cap error on display (blue rocket)
Yeah mine has done this as well. Varies on how long it last
Old May 8, 2007 | 05:47 AM
projectprelude's Avatar
when i installed my zex kit i had to remove the fuel line which caused this message to come on and if you just disconect the barrery it will go away....at least that worked for me
bobinda808
Feb 29, 2012 05:03 AM
dgdarien
May 24, 2009 07:29 PM
DougNuts
May 3, 2007 02:47 PM
sickofitall1113
Jul 9, 2005 03:19 PM
