Wheel size and dyno
no neither a hub dyno or a roller dyno will be affected. The flywheel horsepower numbers may be off a bit given the fact they are calculated using a certian degree of loss. which larger or heavier wheels will have small small effect on.
this is all to the best of my knowledge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsir »</TD></TR><TR><TD CLASS="quote">no neither a hub dyno or a roller dyno will be affected. The flywheel horsepower numbers may be off a bit given the fact they are calculated using a certian degree of loss. which larger or heavier wheels will have small small effect on.
this is all to the best of my knowledge</TD></TR></TABLE>
Thanks for the info, can anyone confirm this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If you go on a dynojet then wheel size will have an effect but depending on the sizes it wont be much. No more then a 5hp throw off.
Dynopack doesnt matter. </TD></TR></TABLE>
17" lead weights....they are heavy going back to 15, or 16's depending on their weight.
