timing belt help
Old May 7, 2007 | 09:28 AM
blakh's Avatar
Default timing belt help
so my car was put in to the mech for them to look at cause i couldnt figure out what was wrong, anyways he said that the timing belt jumped and that i need to replace everything and that it is going to cost me $550ish. i am not about ready to pay that, can i do this myself? id so how? i think the reason my belt jumped is because i hit a bump on the highway really hard, i have shitty coils i havent got around to replacing yet... do i really need to swap the belt out or just put it back and make sure it has tension?
thanks.
Old May 7, 2007 | 09:33 AM
WihaSi's Avatar
Default Re: timing belt help (blakh)
Here's a DIY on a Del Sol, may help. Search the site a bit, you'll find something.
https://honda-tech.com/zerothread?id=649277
Old May 7, 2007 | 09:36 AM
Syndacate's Avatar
It depends on how far off it was.
If it skipped enough to bend a valve, then the 550 includes rebuilding the whole head (which is needed). Though if he wants 550 for a new belt? Screw that, just buy a new tensioner (obviously the tensioner spring is weak if it skipped) and belt and throw 'em both on.
Old May 7, 2007 | 09:44 AM
jdmxsoles's Avatar
Default Re: timing belt help (Syndacate)
wow if there gonna do head work and replace the tensioner and belt then jesus thats a hell of a deal, might as will take my head there hahah..but i really doubt it... that head work would probably be another 500 or so .. GL man
Old May 7, 2007 | 09:45 AM
blakh's Avatar
i dont think anything bent, i really hope not... it happend pretty fast and i didnt hear anything that sounded bad, the car just kinda turned off i had the clutch in when it happend...
Old May 7, 2007 | 09:52 AM
blakh's Avatar
Default Re: timing belt help (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">Here's a DIY on a Del Sol, may help. Search the site a bit, you'll find something.
https://honda-tech.com/zerothread?id=649277</TD></TR></TABLE>
i have b16 so isnt it different?
(not trying to be rude, just asking)
Old May 7, 2007 | 09:58 AM
jdmxsoles's Avatar
does it make a knocking noise if it doesnt then valve isnt bent which luckly didnt happend because valve and piston hitting not good haha..
Old May 7, 2007 | 10:03 AM
blakh's Avatar
it didnt make any knocking sound when hit happend, but i havent had the motor started since then...
Old May 7, 2007 | 10:04 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: timing belt help (jdmxsoles)
Plenty of write-ups around on timing belts.
Do it yourself. If the mechanic says you didn't bend anything you should just DIY.
$550 sounds about right for most shops to do a timing belt on an import. I know it's hanus.
Old May 7, 2007 | 10:07 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakh &raquo;</TD></TR><TR><TD CLASS="quote">
(not trying to be rude, just asking)</TD></TR></TABLE>
Yes most likely, that may give you the general idea...that's why I said "search the site".
Old May 7, 2007 | 10:09 AM
blakh's Avatar
thanks!
hondaaccordf23
Aug 19, 2012 10:05 AM
freshCROOKS
Aug 14, 2012 06:38 PM
slide inside
Oct 22, 2009 09:25 AM
GSRrR
Dec 15, 2001 05:37 PM
