crx si vss
Old May 7, 2007 | 08:24 AM
b16a3delsol's Avatar
Default crx si vss
Im putting a gjdm b16a into my 1988 crx and was wondering if i could use the factroy mechanical vss instead of converting to an electrical vss.
Old May 7, 2007 | 08:37 AM
Slurp56's Avatar
Default Re: crx si vss (lsdelsol)
Yes.
Old May 7, 2007 | 10:16 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: crx si vss (Slurp56)
yes
Old May 7, 2007 | 10:38 AM
redefsir's Avatar
Default Re: crx si vss (sanimalp)
yes
Old May 7, 2007 | 11:12 AM
sneakerfern's Avatar
Default Re: crx si vss (redefsir)
yes sir......
Old May 7, 2007 | 07:51 PM
Default Re: crx si vss (sneakerfern)
redundancy I love it. thanks for the help.
Old May 13, 2007 | 07:45 PM
I fi wanted to change to an electrical Vss how would i do it. I have the plugs and the wires off of the harness. I dont know if they go to the ecu or straight to the speedo.
Old May 13, 2007 | 08:04 PM
Bob_760's Avatar
Signal goes straight to cluster and ecu, other 2 plugs are + and - However you'd need a cluster that had an electronic vss input.
http://www.crxresource.org/mod...d=124
If you really wanna do it.
Old May 13, 2007 | 08:52 PM
ludesrv's Avatar
Default Re: crx si vss (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">Signal goes straight to cluster and ecu, other 2 plugs are + and - However you'd need a cluster that had an electronic vss input.
If you really wanna do it.</TD></TR></TABLE>
Only do it if you have wiring knowledge. Don't hack up what ain't broken.
Old May 13, 2007 | 09:16 PM
Bob_760's Avatar
Default Re: crx si vss (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Only do it if you have wiring knowledge. Don't hack up what ain't broken.</TD></TR></TABLE>
I definately agree with that.
Old May 14, 2007 | 04:55 AM
Im going to buy an sir cluster. I also have the stock b16 harness with the vss plug on it.
99EM1
10
Apr 2, 2008 01:24 PM
eskimo_usd
14
Jun 28, 2006 04:40 PM
urafag
May 14, 2006 12:39 PM
tc_gts
11
Nov 23, 2004 09:30 AM
scul8r1990
Nov 3, 2004 04:15 AM
