97 civic ex wire tuck
Old May 7, 2007 | 08:18 AM
tinkertime's Avatar
Default 97 civic ex wire tuck
does anyone have any pictures of how they did there wire tuck job on a 96-98 civic ex?
Old May 7, 2007 | 08:30 AM
vtecftw's Avatar
Default Re: 97 civic ex wire tuck (tinkertime)
https://honda-tech.com/zerothread?id=1693934
this should keep you busy
Old May 10, 2007 | 06:43 PM
gezzuzz's Avatar
if you are planing to do a wire tuck you need to beable to use a miultimeter.. if you say whats that? stop now.. you also have to know how to solder wires in bulk.. also cant be afriad to cut wires and depin plugs.. in a ek you can hide all the wires that goes to the front of the car running it thru the fenders with out splicing a wire... you can pull the fuse box in the car and have it under the ac unit.. without cutting any wires.. that how i did my friend the first time.. since then i redid it relocating the fuse box to where the air bag is.. and the engine harness.. the big one and little one now go inside the car in the middle right below the heater box..
Old May 10, 2007 | 06:53 PM
harryjohnson's Avatar
Default Re: (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">if you are planing to do a wire tuck you need to beable to use a miultimeter.. if you say whats that? stop now.. you also have to know how to solder wires in bulk.. also cant be afriad to cut wires and depin plugs.. in a ek you can hide all the wires that goes to the front of the car running it thru the fenders with out splicing a wire... you can pull the fuse box in the car and have it under the ac unit.. without cutting any wires.. that how i did my friend the first time.. since then i redid it relocating the fuse box to where the air bag is.. and the engine harness.. the big one and little one now go inside the car in the middle right below the heater box.. </TD></TR></TABLE> any pics ive been wanting to do this but i dont want to take off my ac and cc
hardcore97
Sep 11, 2012 06:50 PM
kreatekustomz
Welding / Fabrication
11
Aug 3, 2009 08:36 AM
existanzcivicb20
Mar 4, 2009 08:35 PM
2slow4stock
Dec 3, 2007 12:29 PM
92_honda_hatch
Sep 28, 2006 09:06 PM
