Converting obd 0 to obd 1. need run thru(help)
ok i am gonna do this in a week and got most of the parts. just need headgasket and timing belt. i need a guide on the converting obd0 to obd1 cuz this is the only thing i aint never done. i will be using a z6 head complete on a 89 std hatch.
My main question is what do u do with the harness i got both harness complete but i have no idea if i use the 89 or the 93 or even what to splice together.
Use your stock harness. If it isn't already converted to MPFI, best to do it now. From there, change ECU pinouts from OBD-0 to OBD-1 through use of a harness or hardwiring. Run extra wires for VTEC, 4-wire O2 to engine bay. Enjoy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Use your stock harness. If it isn't already converted to MPFI, best to do it now. From there, change ECU pinouts from OBD-0 to OBD-1 through use of a harness or hardwiring. Run extra wires for VTEC, 4-wire O2 to engine bay. Enjoy
Lets say u have the head on and have everything bolted up. And have the obd0 to obd1 harness in place with a P28 and ran the wires for the vtec sol. and 4 wire o2 to the engine bay and splice them to the plugs and plug them to the sensors. what would be next? like the fuel injectors do u need to splice in the plugs from the obd 1 harness?
</TD></TR></TABLE>Lets say u have the head on and have everything bolted up. And have the obd0 to obd1 harness in place with a P28 and ran the wires for the vtec sol. and 4 wire o2 to the engine bay and splice them to the plugs and plug them to the sensors. what would be next? like the fuel injectors do u need to splice in the plugs from the obd 1 harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 »</TD></TR><TR><TD CLASS="quote">Lets say u have the head on and have everything bolted up. And have the obd0 to obd1 harness in place with a P28 and ran the wires for the vtec sol. and 4 wire o2 to the engine bay and splice them to the plugs and plug them to the sensors. what would be next? like the fuel injectors do u need to splice in the plugs from the obd 1 harness?</TD></TR></TABLE> You have the option of using the OBD-0 Injectors and keeping your injector resistor box or deleting the injector resistor box and using OBD-1 injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Janos Lin »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1508680
there's a walkthrough in there.
Janos</TD></TR></TABLE> Yup, that'd be mine I believe, I need to add some more diagrams to it...thanks for reminding me
That was fast!!
I checked it out. So i guess i have to regardless get a SI harness too?????? Even if i am gonna use the obd 1 injectors.
Ok according to these instruction on rywire.com i need that plug(which i have)
OK OK i know what i am trying to ask now.
Since i am dpfi now once add the head where do i run the wires from the obd 1 injector clips?????
t-town_ep
Nov 19, 2012 12:54 AM
John The G
10
Oct 22, 2010 06:44 PM
bobbyisking
Jul 7, 2008 09:22 AM
KevronsEG
11
Jun 28, 2002 09:23 AM
