ignition
Old May 6, 2007 | 08:23 PM
themex77's Avatar
Default ignition coil
i installed my 2 subs and when i went to turn on my car my check engine light i went on and i cranked it anyways but nothing happened it turned but did not start im sure that theres fuel so i took off my wires to see if there was spark and there was nothing so i took of my distributor cap and i saw that my ignition coil was cracked took it off and saw that it had more cracks is that bad? i also tried to check it with the omh meter but it gave me .002 and im not sure if im doing it right you just have to take the ohm ends and put them on the + and - terminal right.
90 crx w/b16 and 0db0 ECU
thanks
Modified by themex77 at 9:37 PM 5/6/2007
Old May 6, 2007 | 08:56 PM
abnaasefmb's Avatar
Default Re: ignition coil (themex77)
if your cap rotor or coil are cracked replace them. thats a good starting point.
Old May 7, 2007 | 04:49 PM
themex77's Avatar
Default Re: ignition coil (abnaasefmb)
any 1 else
thanks
Old May 7, 2007 | 05:04 PM
Janos Lin's Avatar
If its cracked, dont bother trying to see if its still any good. Electricity will take the path of least resistance, and if thats out of the crack in the coil to someplace else, it will. Toss it and get another. I bet ur subs caused the coil to shatter
Janos
Old May 7, 2007 | 05:45 PM
themex77's Avatar
Default Re: ignition coil (Janos Lin)
thanks where do you think i can get the cheapest coil the cheapest one i seen was 59.99 i was thinking about getting one in the junkyard since coils hardly go out right what about ebay?
Old May 7, 2007 | 05:47 PM
Janos Lin's Avatar
It's hard to kill a coil, yeah, but you can get a brand new distributor for like 200 from Distributor King just in case you're willing to consider them.
Janos
Old May 8, 2007 | 05:33 PM
themex77's Avatar
i replaced my coil and autozone said that my ICM was good they tested it 7 times so now im stuck any one have any more ideas could it be my main relay there are also no codes
thanks
Modified by themex77 at 7:00 PM 5/8/2007
Old May 8, 2007 | 06:23 PM
themex77's Avatar
could it be my ECU?
Old May 8, 2007 | 08:56 PM
innes887's Avatar
look under the passenger side carpet to see if the ecu is blinking. if it has a solid red light on it then its bad. you check it by turning the car to the on position so everything powers in the car. then it should blink once, then pause, and then if you have a code it will blink more. count the number of blinks and thats your code. check the coil wire. or wireing going to it. and check the new coil. just because its new dosent mean its good
Old May 9, 2007 | 11:07 AM
Janos Lin's Avatar
Default Re: (innes887)
are you getting sparks when cranking the engine?
Janos
Old May 9, 2007 | 02:03 PM
themex77's Avatar
Default Re: (Janos Lin)
no spark and no codes i dont hear my fuel pump going on too im starting to think its my main relay does any one know where its at?
Old May 9, 2007 | 04:54 PM
themex77's Avatar
*update*
i took off the main relay and resaudered the pins but still no go my check engine light is still on and im still not getting any codes any have any more ideas?
thank for all the input
mjp2870
Oct 28, 2018 07:49 AM
ezcape
Apr 14, 2011 12:55 PM
95blackEG
Dec 24, 2008 07:59 PM
bennyDA
Nov 9, 2006 04:28 AM
MrFast4Ward
May 19, 2004 09:47 PM
