Taillights.. 96-98 and 99-00
Old May 6, 2007 | 07:51 PM
geebs's Avatar
Default Taillights.. 96-98 and 99-00
Im looking to change my taillights from the red/orange/clear oe style to the red/clear style.. but i dunno if i have to change from a 96 4dr to a 99 4dr.. or can i use the 2dr taillights? are they all interchangeable? or do i need to swap from the same model?
Old May 6, 2007 | 07:52 PM
ke98248's Avatar
Default Re: Taillights.. 96-98 and 99-00 (geebs)
you cant use a 2dr coupe's tail lights, only 4 dr. Sorry!
This is the easiest "swap": Unbolt the few bolts, take out the old lights, put in the new ones, and bolt the new ones back in... You'll need a racket with a few deep socket sizes, not sure if they're 10mm or 12mm nuts.
Old May 6, 2007 | 07:54 PM
bmoua's Avatar
well i'm guessing this question is for civics???
2 door tail lights will only work on 2 door tail lights. As for the 96 4dr civics and 99 4dr civic tail lights being compatiable?? i'm not too sure...bump...
Old May 6, 2007 | 07:55 PM
BlueIntegraBoy's Avatar
If you plan to swap to 99-00, and your car is a sedan, you will also need the 99-00 trunk along with the tail lights.
The 99-00 sedan tail lights have orange, so you need to go aftermarket for the red/clear tail lights for a 96-98 sedan.
Old May 6, 2007 | 11:46 PM
NOFX's Avatar
H-T White Ops
'99-'00 USDM sedan taillights still have amber in them.
If you have a '96-'98 Civic sedan you might want to call up a parts importer and see if they can get ahold of some Integra SJ taillights. Looking at them they look like they might fit. I haven't seen them on a Civic so far.
This model IS NOT the Integra we're used to seeing. It's based off of the 6th gen Civic sedan.
For those with '99-'00 sedans, the Philipines also has red/white sedan tailights for the '99-'00 sedan that come stock. At least the owner (lestah on ClubCivic) of this car said they were stock.
Modified by NOFX at 12:57 AM 5/7/2007
Old May 7, 2007 | 12:25 AM
Default Re: (NOFX)
Trying to find Integra SJ lights will be hard unless you know someone in Japan. An alternative is to go aftermarket.
Old May 7, 2007 | 12:39 AM
Eran's Avatar
HT White Ops
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Trying to find Integra SJ lights will be hard unless you know someone in Japan. An alternative is to go aftermarket.</TD></TR></TABLE>
But I'm sure the Philippines ones will be a snap to find
The SJ tails will probably be a lot easier to find since most used JDM retailers have buyers in Japan .... I'm willing to bet zero have buyers in the Philippines.
Old May 7, 2007 | 12:44 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">If you have a '96-'98 Civic sedan you might want to call up a parts importer and see if they can get ahold of some Integra SJ taillights. Looking at them they look like they might fit. I haven't seen them on a Civic so far.
This model IS NOT the Integra we're used to seeing. It's based off of the 6th gen Civic sedan.</TD></TR></TABLE>
Any company that deals in importing over JDM cars and parts should be able to find them.
Old May 7, 2007 | 07:18 PM
Default Re: (NOFX)
Any company that deals in importing over JDM cars and parts should be able to find them.</TD></TR></TABLE>
Not a matter of finding the cars in Japan, but having interest in selling to US consumers. I hardly see any Integra SJ parts for sale, being that it is a 4-dr Civic, still... never seen those tail lights for sale.
Old May 7, 2007 | 08:06 PM
GG99's Avatar
or he can get some ebay red and clear taillights, and save time and money.
tho i cant vouch for the quality..
Old May 7, 2007 | 08:16 PM
ikillradio's Avatar
Default Re: (NOFX)
or the Canadian Acura EL
Old May 7, 2007 | 09:08 PM
Default Re: (ikillradio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikillradio &raquo;</TD></TR><TR><TD CLASS="quote">
or the Canadian Acura EL </TD></TR></TABLE>
Yes, but he'll need the trunk too.
Old May 7, 2007 | 09:17 PM
nyc2sc's Avatar
just get some red and whites off ebay
Old May 7, 2007 | 09:18 PM
B18CivicEH2's Avatar
from the looks of it, i highly doubt the Integra SJ taillights will fit...the outer ones MIGHT but the ones on the TRUNK will def NOT fit...
Old May 7, 2007 | 10:43 PM
Default Re: (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 &raquo;</TD></TR><TR><TD CLASS="quote">from the looks of it, i highly doubt the Integra SJ taillights will fit...the outer ones MIGHT but the ones on the TRUNK will def NOT fit...</TD></TR></TABLE>
Looks to the same to me.
Old May 7, 2007 | 10:51 PM
im looking at this pic here, and if you look at the inter light thats on the trunk, you'll notice the bottom is longer then the top in length...
now, if you look at the SJ, you'll notice that both, bottom and top parts of the light are equal in length....
so thats why i said they wouldnt fit..
Old May 7, 2007 | 10:57 PM
alacard's Avatar
Yeah, they wouldn't fit the 99-00 usdm sedan, but assuming he is talking about the 96-98 sedan, they will probably fit.
Old May 7, 2007 | 10:58 PM
ikillradio's Avatar
Yes, but he'll need the trunk too.</TD></TR></TABLE>
not if he has a 96-98, you only use the outer pieces and its a direct fit
Old May 7, 2007 | 11:09 PM
not if he has a 96-98, you only use the outer pieces and its a direct fit</TD></TR></TABLE>
Yeah, I guess since he's only looking for the red/clear look. I assumed you wanted him to do the whole conversion.
Old May 8, 2007 | 12:16 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Not a matter of finding the cars in Japan, but having interest in selling to US consumers. I hardly see any Integra SJ parts for sale, being that it is a 4-dr Civic, still... never seen those tail lights for sale.</TD></TR></TABLE>
Companies that already import JDM parts will see it as a sale. I believe the market is there. LOTS of sedan owners would like to have the OEM red/white lights too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikillradio &raquo;</TD></TR><TR><TD CLASS="quote"> http://upload.wikimedia.org/wi...9.JPG
Of course, but then there's more work involved. What if the owner likes the Civic trunk?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 &raquo;</TD></TR><TR><TD CLASS="quote">im looking at this pic here, and if you look at the inter light thats on the trunk, you'll notice the bottom is longer then the top in length...
so thats why i said they wouldnt fit..</TD></TR></TABLE>
The top photo is a '99-'00 USDM Civic sedan. The '99-'00 Civic sedan taillights from the Philippines will fit it and be red/white. Look in the photo I posted above to see the red/white '99-'00 taillights from the Philippines.
The cars at the bottom is an Integra SJ. Those taillights will fit the '96-'98 USDM Civic sedan.
The more I look around, the more it seems that most overseas '96-'98 Civic sedans (and their similar models) have red/white taillights. I see them in the Philippines, Europe and Japan. The European and Japanese ones so far are the Integra SJ, but in the Philippines I see some that are Civic sedans with them. I'm not sure if this is for all of them though or if it's a mod.
So again, I'll go over it. Trying to lessen confusion.
Remember though, this is just a selection of what is out there. There are MANY other Hondas based on the 6th gen Civic and other Civics we aren't all familiar with. So there are many many many OEM parts out there that most people aren't familiar with at all.
'96-'98 EDM Civic SiR sedan
'96-'98 EDM Integra SJ
'99-'00 Philippino Civic sedan
Backwoodz
May 25, 2010 04:58 PM
rustydusty1717
Lighting
May 13, 2009 01:47 PM
GreenEX
Oct 12, 2003 07:27 PM
. B i g T R Q
Jun 10, 2002 09:31 PM
