what sensor is this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">If it was oil pressure sensor you'd be throwing a code. it's likely your knock sensor and you must have an ecu that doesn't look for the knock sensor.</TD></TR></TABLE>
Really? What code would he throw?
There are not that many sensors on the GSR motor under the IM. There is the IAB which is part of a black box looking thing. There is the knock sensor, which is typically a green sensor above your water pipe, the oil pressure sensor which controls the oil light in your cluster. It's typically a 1 prong sensor. You've also got your radiator fan temp switch in your thermostat housing. And then if you have power steering there is a sensor in your power steering line.
The only sensors that will throw a code are the Power Steering Pressure Switch and the Knock Sensor.
Also, since its a '96 motor, there should be a Crank Fluctuation Sensor mounted on your oil pump housing. The connector typically sits near the timing cover. You will throw a code for this if you're running an OBD2 ECU.
jjaskula1
Nov 26, 2005 01:13 PM
