Can you drill 4X114 type-r wheels to 4x100?
Old May 6, 2007 | 04:22 PM
blackhope121's Avatar
Default Can you drill 4X114 type-r wheels to 4x100?
I am not an expert but is there some sort of factor that keeps you from doing this. Drilling 4 more lugs and making type r wheels a universal 4 lug wheel?
Old May 6, 2007 | 04:24 PM
BlueIntegraBoy's Avatar
Default Re: Can you drill 4X114 type-r wheels to 4x100? (blackhope121)
If it was possible, you would lose structural integrity of the rim. I highly don't recommend doing it, and would highly recommend that you convert to 4x114.3.
vtecftw's Avatar
Well it would look like ****
wreck type R wheels
lower the structural integrity and balance of the wheel
just take the time to convert my friend
Old May 6, 2007 | 05:25 PM
t0p_sh0tta's Avatar
Agreed...
Convert to 4x114, find some knockoffs or find another wheel.
Old May 6, 2007 | 06:23 PM
Kidnkorner's Avatar
in the past i have seen expensive aftermarket wheels stripped down to bare metal and the stock holes welded then the wheels were re drilled for another bolt pattern and powder coated. With precision craftmanship I wouldn't see why it couldnt be done.
Old May 6, 2007 | 06:29 PM
Eran's Avatar
HT White Ops
If you're going to be ghetto, just paint some HX's white.
Old May 6, 2007 | 06:37 PM
t0p_sh0tta's Avatar
Default Re: Can you drill 4X114 type-r wheels to 4x100? (Lynx Bus Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynx Bus Type R &raquo;</TD></TR><TR><TD CLASS="quote">in the past i have seen expensive aftermarket wheels stripped down to bare metal and the stock holes welded then the wheels were re drilled for another bolt pattern and powder coated. With precision craftmanship I wouldn't see why it couldnt be done.</TD></TR></TABLE>
I can easily see that costing more than a 4x114 swap.
Old May 6, 2007 | 06:39 PM
Eran's Avatar
HT White Ops
Default Re: Can you drill 4X114 type-r wheels to 4x100? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">
I can easily see that costing more than a 4x114 swap.</TD></TR></TABLE>
Seriously, $700 with ITR wheels.
Old May 6, 2007 | 07:06 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Can you drill 4X114 type-r wheels to 4x100? (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">
i sell 4x114.3 complete front + rear brake conversion and ITR wheels with tires for $650</TD></TR></TABLE>
OP: Problem solved ^
Old May 6, 2007 | 08:35 PM
Kidnkorner's Avatar
I agree. The cost would outweigh the benefit here. In the case Im speaking about was in the late 90's where a race team was competeing with a Pontiac Sunfire GT, and the wheels they wanted to use didnt come in the offset AND bolt pattern they needed. So they did what I had mentioned.
Old May 6, 2007 | 09:04 PM
confucioussae's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhope121 &raquo;</TD></TR><TR><TD CLASS="quote">I am not an expert but is there some sort of factor that keeps you from doing this
yes, common sense.
if you cant afford a 4x114 swap, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">just paint some HX's white.</TD></TR></TABLE> and save up
Old May 7, 2007 | 07:11 AM
pkdog167's Avatar
Default Re: Can you drill 4X114 type-r wheels to 4x100? (confucioussae)
If they can be done, some one should did it already
Old May 9, 2007 | 12:31 PM
NIKE SB'd's Avatar
96R wheels suck anyway.
Old May 9, 2007 | 12:40 PM
pimpinblackcivic's Avatar
agreed
Fitz Williams
Aug 6, 2017 05:59 AM
Jvs10
Jan 30, 2010 01:38 PM
Shakey021
Welding / Fabrication
Jan 7, 2010 05:03 PM
Khmerican
May 14, 2008 03:25 PM
89a6T
Suspension & Brakes
Mar 1, 2006 03:39 PM
