b16b, friend pulled wire off dizzy cap while running and then reconected it, wont start
Old May 6, 2007 | 03:21 PM
vtecftw's Avatar
Default b16b, friend pulled wire off dizzy cap while running and then reconected it, wont start
Yeah i know this is stupid as hell, my friend did as stated above and the car turns over but wont start. Does anyone have a clue what could of happened?
Old May 6, 2007 | 03:59 PM
vtecftw's Avatar
bump please help
Old May 6, 2007 | 04:04 PM
vtecftw's Avatar
bump
Old May 6, 2007 | 04:07 PM
Cboi's Avatar
im think'n he broke the pin on the inside of the dizzy cap
Old May 6, 2007 | 04:11 PM
vtecftw's Avatar
Default Re: (Cboi)
how would i be able to tell if it has been broken off, when i removed the cap there we shavings in the cap.
Old May 6, 2007 | 04:20 PM
Cboi's Avatar
go get a new dizzy cap n he should be str8
Old May 6, 2007 | 04:22 PM
vtecftw's Avatar
Alright so the only issue would be my dizzy cap? becasue the inside of the cap doesnt seamed to be harmed but there are shavings
Old May 6, 2007 | 04:46 PM
vtecftw's Avatar
there is no damage to the inside pin of the Dizzy. Help please
Old May 6, 2007 | 10:19 PM
gwegcivic's Avatar
Default Re: (vtecftw)
i know it sounds stupid but did you check both fuses?
Old May 6, 2007 | 10:27 PM
gezzuzz's Avatar
Default Re: (gwegcivic)
pulling a wire off while running will no hurt your car... mechanics do it all the time.. replace the cap if it broke by just pulling a wire off it was going to break anyways.. they cheap.. replace the rotor too
Old May 7, 2007 | 12:30 PM
vtecftw's Avatar
Default Re: b16b, friend pulled wire off dizzy cap while running and then reconected it, wont start (vtecftw
what fuses would i check?
Old May 7, 2007 | 12:37 PM
geebs's Avatar
you can hurt the coil when pulling a wire off the dizzy when its running.. id check for spark to be sure its not that..
Old May 7, 2007 | 01:38 PM
sledgehammer.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geebs &raquo;</TD></TR><TR><TD CLASS="quote">you can hurt the coil when pulling a wire off the dizzy when its running.. id check for spark to be sure its not that..</TD></TR></TABLE>
Old May 7, 2007 | 06:56 PM
vtecftw's Avatar
yeah i just ordered a new one from dizzy king
who wants a ctr dizzy from a b16b they can fix for cheap?
Old May 7, 2007 | 07:01 PM
jpnucrx's Avatar
Default Re: (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">pulling a wire off while running will no hurt your car... mechanics do it all the time..</TD></TR></TABLE>
actually it does mess your car up...it causes it to misfire and put raw fuel through the exhaust and raw gas ruins your catalyst...mechanics dont do that all the time, they temp disable componets by disconnecting fuel or spark to find a problem, well a real mechanic anyway...anywho
Old May 7, 2007 | 10:38 PM
Sketch_hs's Avatar
probably killed the coil, same thing happened to me once.
Old May 7, 2007 | 10:43 PM
Team RS2's Avatar
Default Re: (jpnucrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx &raquo;</TD></TR><TR><TD CLASS="quote">actually it does mess your car up...it causes it to misfire and put raw fuel through the exhaust and raw gas ruins your catalyst...mechanics dont do that all the time, they temp disable componets by disconnecting fuel or spark to find a problem, well a real mechanic anyway...anywho</TD></TR></TABLE>
and if they dont they are only mechanics for a very short period of time
Old May 8, 2007 | 04:14 AM
blackKready's Avatar
Default Re: (Team RS2)
tell your buddy to keep his hands off your fukin car if hes gonna be an idiot. id make him pay for it personally.
Old May 8, 2007 | 04:15 AM
EE_Chris's Avatar
Default Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">probably killed the coil, same thing happened to me once.</TD></TR></TABLE>
x2
And that red dust inside your distributor cap is the bushing in the cage taking a ****.
Old May 11, 2007 | 04:44 PM
vtecftw's Avatar
thanks alot guys
my new dizzy from dizzy king should be here anyday
averyvm
May 8, 2009 11:37 PM
Integra4lyfe069
Nov 9, 2008 12:22 PM
ianae86
12
Apr 12, 2006 06:05 PM
thug252
14
Oct 24, 2004 04:58 PM
t25hatch
Oct 20, 2004 11:10 AM
