big_t's intro and crx project
hey guys my name is Travis and i just recently made the conversion from 2 240sx's to my new crx. i needed something reliable to get to college so i ditched the 240sx and picked up this crx for 2700. i needs a lil work (oil leak, need bumper lenses, ect.) but it has a ls swap with normal bolt ons and it lowered on sleeve coil overs. plans are to first get it in tip top shape and the rest of my plan will be a secret until i update this thread.
here is a few pics i snapped when i first got it.
ill post my pics after i clean her up
Modified by BIG_T at 12:26 AM 8/15/2007
Modified by BIG_T at 12:29 AM 8/15/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 »</TD></TR><TR><TD CLASS="quote">nice car, i like your wheels, not flashy at all but better than stock, my taste atleast. </TD></TR></TABLE>
HXs
What's wrong with the bumper lenses?
HXs
the bumper lights dont have any lenses in them (need to get some asap)! i just ordered a morso battery box since the previous owner had a ghetto wood box. thanks for the welcome guys. the only rust on the hole car is the rear quarter which isnt even all the way through
. i guess ill ask my question on my thread. the shifter has alot of paly when im driving. if i let off the gas the shifter will move downward and while in gear if i move the shifter from side to side it is also very loose. any ideas?
thats what i figured but now i have a total noob question. (im here to learn right
) do i need a shifter bushing for a crx or a integra since it has the ls swap? thanks for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mykoe817 »</TD></TR><TR><TD CLASS="quote">new shifter bushings. their cheep. 15 - 20$ at a auto store.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">get the energy suspension ones. also tighten the bolt on the bottom of the shifter.</TD></TR></TABLE>
x2
also nice crx ef's look good on some hx's. good luck and welcome to h-t.
x2
id say integra since you have to have custon linkage anyway. but i realy dont think there is a diffrence in them. but id say the integra one. now i could be wrong so someone correct me if i am.
also, you probably dont have the spring pin that connects the shift linkage to the tranny. its called the "bitch pin".
mine does that right now, since i just did an auto to manual swap in my 91 hatch, and didnt have an extra pin, so i used a 12mm bolt. sometimes i forget what gear im in, because the shifter has so much play
As for bushings It IIRC you need ENS-16-1101R (summitracing part #) so one for a 99-00 Si, GSR, ITR, it's all the same part. The CRX one will have a D-Series trans bushing which won't fit.
Before I got new bushings I'd check the linkage out though, it could need the little rubber bushings between the shifter itself and the linkage, the bitch pin could be replaced with a bolt as previously stated, it could be alot of things. Allthough regardless the ES bushings will make things nicer.
I had 2 Integras with the "loose shifter" Its more than likely one of 2 things, the ES bushings will help but not solve the problem...either the "U" joint is bad on the end of the linkage(or a bolt was used instead of the bitch pin) or the more likely problem is the bushing on the bottom of the shifter itself is loose...just grab a new shifter or short shifter and you'll be good to go...
Oh nice rex I love HX/VX wheels!!
well guys i found out what the shifter moving around was caused from. the previous owner used a crx rear mount bracket and cut it way to much. so i picked up a 90-93 teg one. this saturday more goodies are going on it. ill take pics
well it has come along ways guys ill update soon. i have learned tons of stuff since i first picked it up. i redid the swap added some goodies and fixed tons of **** poor **** the previous owners did
ill post pics tomorrow when i clean it up
i heart honda
Nov 30, 2006 10:57 AM
i got a word from a local rex owner so im ordering a energy suspension teg shifter bushing.
