Best Oil to Use?
Hey everyone. I'm curious as to what kind of oil you guys use in your Civics....like what brand do you prefer? is it regular, high-mileage or synthetic? what viscosity? I have been using Castrol GTX High-Mileage 5W30 religiously ever since I got mine nearly 3 years ago, and I find it works alright ( 190,000km on engine), but I've been thinking of switching to full synthetic. I'm just not sure if it will be beneficial to do it. Any suggestions or comments? Thanks!
As stated, this has been discussed many, many times. You'll find a lot of information by using the search feature. Personally, I'd stick with what you're currently using, and perhaps send out a sample for a UOA to determine how well it's working. With oil threads like these, you're going to likely get a different opinion in almost every reply. In the end, any quality 5W-30 changed at reasonable intervals will be perfectly fine. If you really want to get into discussions regarding motor oil, you can also check out the Bob Is The Oil Guy forums.
i work in an automotive shop and we normally put 10w30 in the cars but most hondas call for 5w30 or 5w20.we only use penzoil unless some one brings there own oil in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">As stated, this has been discussed many, many times. You'll find a lot of information by using the search feature. Personally, I'd stick with what you're currently using, and perhaps send out a sample for a UOA to determine how well it's working. With oil threads like these, you're going to likely get a different opinion in almost every reply. In the end, any quality 5W-30 changed at reasonable intervals will be perfectly fine. If you really want to get into discussions regarding motor oil, you can also check out the Bob Is The Oil Guy forums. </TD></TR></TABLE>
Supertech ftw!1
Supertech ftw!1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote"> In the end, any quality 5W-30 changed at reasonable intervals will be perfectly fine. </TD></TR></TABLE>
/oil discussion for hondas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Castrol GTX is good oil.
There are very few "bad" oils.
oil is oil, cheange it when you're supposed to.
</TD></TR></TABLE>There are very few "bad" oils.
I use quaker state high rpm synthetic blend 20 50. Been using it for years already. Never failed me
. If your in a colder area get 5w20. I just use the thicker oil since its pretty hot over here during these times of the year. I tried royal purple and also mobil but i felt like there wasn't much difference at all in all the oils. It just depends on your tastes and stuff basically
. Like the other guy said, oil is oil
I felt like though castrol turned black pretty fast. quake state didn't turn as black as fast. Royal purple lasted as much as quaker. Not sure about mobil since its been awhile but if you want the high end stuff get the royal purple
I use Mobil 1 Fully Synthetic Extended Performance 10w30. I still change it every 3,000 miles just as a safe rule of thumb. I'm thinking that I will go down to 5w30 though as Honda recommends because I have a little bit of a tap that is annoying and I may have to go down a notch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">10-30 Synthetic will do the trick.</TD></TR></TABLE>
Sure it will, if you live in the Sahara
5w-30 it's what your car manual tells you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 »</TD></TR><TR><TD CLASS="quote">I use Mobil 1 Fully Synthetic Extended Performance 10w30. I still change it every 3,000 miles just as a safe rule of thumb. I'm thinking that I will go down to 5w30 though as Honda recommends because I have a little bit of a tap that is annoying and I may have to go down a notch. </TD></TR></TABLE>
What a waste of money. I use synthetic and I change mine every 5,000 miles.
I even sent in a sample and they told me I could wait another 1-2,000 miles before changing.
If you're going to pay 2-3 times as much for synthetic oil that's designed to go for 5-9 thousand miles why would you change it WAY before it's scheduled change time?
That's like using conventional oil and changing it every 200 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 »</TD></TR><TR><TD CLASS="quote"> I still change it every 3,000 miles just as a safe rule of thumb. </TD></TR></TABLE>
What a waste of money, really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amborghini »</TD></TR><TR><TD CLASS="quote">i cant remember what does the two numbers mean for example>> 5w30? what the 5 and the 30 mean?</TD></TR></TABLE>
Essentially, the first number indicates how the oil performs at low temperatures, and the second number indicates the viscosity at high (operating) temperatures.
vtec25
Sep 3, 2006 11:10 AM
