Clutch and flywheel torque measurements for a 98 GSR
Old May 6, 2007 | 05:27 AM
chargedgsr99civic's Avatar
Default Clutch and flywheel torque measurements for a 98 GSR
I have a 98 Integra GSR and I need the to torque measurements for the flywheel and the clutch. I can't remember but I think the clutch is only 16lb but not sure about it and the flywheel I think it is around 76lb but again not sure about either.
Old May 6, 2007 | 12:25 PM
turbo_ls_69's Avatar
the flywheel is 76 lbs and the pressure plate is 24 lbs
Old May 7, 2007 | 04:11 AM
Default Re: (turbo_ls_69)
Thanks for the info.
Old May 7, 2007 | 04:31 AM
LordAphotic's Avatar
those numbers didnt seem right to me so i double checked the helms manual...
Flywheel was correct at 76ft-lbs but the pressure plate is actually only 19ft-lbs.
Remmember to tighten it the way you would tighten the rim of a car. diagonal to diagonal... also use thread locker...
danthemang3
Jun 20, 2009 11:37 PM
SLOENUF
Aug 12, 2006 01:07 AM
atmosphere
Sep 8, 2005 07:15 AM
project-boosteD
Nov 30, 2004 09:41 PM
EGHatchy
Jun 28, 2002 11:19 AM
