car when at idle drops to almost zero and when slowing down cuts off
okay i have a f22b1 sohc vtec and i have been having trouble first i replaced the serpentine belt then i been having trouble. it was throwing a egr valve check light and i cleaned the port and replaced the egr valve. that helped a little now its riding rough. the rpms go to zero when i stop and the car stalls. i dont have vtec hooked up i need to know what ecu to use its been like that for a month the motor is obd2 and the car is obd1 can anyone help
If you put a serpentine belt on an F22B1 you really do have a problem
Check accord FAQ's and try cleaning the IACV and FATV
