Header clearance "?"
thats wierd, a stock b16 manifold should clear.
if not, you can either hack it (not recommended), go with and innovative mounts crossmember, or get a traction bar system.
do some research with the search button up top. make sure you choose the archived option when you are seraching.
good luck
good luck
if you hack up your crossmember MAKE SURE your WELD support metal where you cut to make it stronge again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 »</TD></TR><TR><TD CLASS="quote">this is what i did but its welded metal to support wat is cut out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">or buy a header that doesnt stick out so damn far.</TD></TR></TABLE>
No, start hacking.
It's just to big stock X member to fit any header in there, heck some people even need to just for an oem b16 exhaust mani.
There was like none of mine left before I upgraded my X member lol.
No, start hacking.
thats a factory manifold.
lol im with streetwerkz. shame on you. but if you have nice tough poly mounts and want to drive the car cut that piece off if you planning on replacing it anyways. btw, that mount is NOT integral to the motors movement in the engine bay. have you seen the size of the stocker???its TEENY!!! cut it and dont worry. or buy an aftermarket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9_civic_hatch »</TD></TR><TR><TD CLASS="quote">No I used AVID mounts.</TD></TR></TABLE>
I don’t know whats up with your header but, it looks like from the pict that your motor is sitting too far forward when ive swapped out an EF even with a b20 ive never had a problem with the header clearance id look in to those mounts and see if any one has had similar problems. Sorry I couldn’t be of more of a help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
no there not those look like itr/4-1 after market headers if they were stock B16A headers they would have 1 or 2 O2 sensors on the upper header. but the one above it is. Good try tho.
</TD></TR></TABLE>no there not those look like itr/4-1 after market headers if they were stock B16A headers they would have 1 or 2 O2 sensors on the upper header. but the one above it is. Good try tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9_civic_hatch »</TD></TR><TR><TD CLASS="quote">yea its stock, I had itr header but didn't fit, so i sold them and i put the stock header on so i can take pics too post them.</TD></TR></TABLE>
good try tho...
good try tho...
thats a factory manifold. </TD></TR></TABLE>
ya..i was talkign about the last picture not the stock manifold
in that last picture it looks like there was way more cutting then was necessary. i would rather cut or hammer the lip down then cut half the thing out. or get an aftermarket x member.
my stock bseries header fits perfect. you fucked something up. get an aftermarket tractoin bar
http://www.explicitspeedperfor....html
