OBD I and OBD II Injector Differences - Did search
I have heard conflicting answers about the clips used buy on the injectors.
Are the clips for OBD I and OBD II the same? My primary interest is in the Integra clips.
Second, I need help with a light throttle problem. When I am cruising at part throttle the car will stumble and hesitate. If I apply full throttle then it will snap out of the stumble and surge forward. Any ideas? Please!
Thanks in advance.
Thanks in advance.
Speeds: Do you know where I could aquire a TPS sensor? I know the only way to get one through honda is to buy the whole throttle body. But I do not like that option, too much $.
The 96 GS-R seems to be an oddball year. Even though that car is OBD2, many people have run a 96 GS-R ECU with a test pipe and the ECU doesn't complain.
I can say for certain that 97+ clips are NOT the same as OBD1 clips. I've had several different mixes and matches of injectors and clips and the OBD2 clips are definitely different.
Sonny
Sonny
Sonny:
If you remember Honda got in to a bit of trouble with the '96 ECU. The program was closer to an OBD I code than an OBD II code. There was a recall or a service bulletin about it. So that would explain why there was no CEL.
Colorado_teggy
Feb 26, 2014 01:08 PM
