Taillight Conversion
Old May 5, 2007 | 12:34 PM
TrunkRattlin's Avatar
Default Taillight Conversion
Is it a simple conversion to switch from the stock 96-98 taillights to the SI red/white tails?
Old May 5, 2007 | 12:46 PM
HcOiNvDiAc's Avatar
yes they are both changable with each other
Old May 5, 2007 | 12:47 PM
PinoyxEJ6's Avatar
Default Re: Taillight Conversion (TrunkRattlin)
yeah, it should bolt right up. Because thats what i did, i got a 97 civic and used 00civic si tail lights. And they are simple as plug & play.
Old May 5, 2007 | 12:56 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Taillight Conversion (Yikez itz Jayr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yikez itz Jayr &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it should bolt right up. Because thats what i did, i got a 97 civic and used 00civic si tail lights. And they are simple as plug & play.</TD></TR></TABLE>
Yep, all you have to do is swap the bulb sockets into the new taillight housing.
FYI all coupes/hatches in 99-00 came with red/clear taillights.
Old May 5, 2007 | 01:15 PM
NOFX's Avatar
H-T White Ops
The bulbs will not simply swap over. All the coupe taillights bulbs are the same EXCEPT the turn signals.
If you plan to swap to the newer taillights, make sure you also have the '99-'00 wiring harness from the lights.
There are amber bulbs that fit in the '96-'98 turn signal sockets, but they are harder to find and more expensive than the amber bulb for the '99-'00 turn signal sockets.
Old May 5, 2007 | 01:18 PM
Team RS2's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">The bulbs will not simply swap over. All the coupe taillights bulbs are the same EXCEPT the turn signals.
There are amber bulbs that fit in the '96-'98 turn signal sockets, but they are harder to find and more expensive than the amber bulb for the '99-'00 turn signal sockets.</TD></TR></TABLE>
what we did at the shop (because the guy wanted to save some money on bulbs) was buy an ornage bulb condom to slip over the bulb, the clear bulbs are a good dollar to a dollar 50 cheaper than the amber
Old May 5, 2007 | 01:20 PM
Ek Forever y0!
Default Re: (Team RS2)
I never had a problem with that on my 97 hatch. It had 00 hatch tailights on it.
I guess I just got lucky and found the right bulb?
Damn, NOFX is teaching me new ish all deh time.
Old May 5, 2007 | 01:41 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">what we did at the shop (because the guy wanted to save some money on bulbs) was buy an ornage bulb condom to slip over the bulb, the clear bulbs are a good dollar to a dollar 50 cheaper than the amber </TD></TR></TABLE>
The bulb condoms can't be found at all stores. Also, the bulbs usually come in packs of two, so even if the amber were a whole $1.50 more, you're getting two bulbs.
When the wire harnesses come with the '99-'00 coupe taillights, it does not increase the value of the used taillights. I've seen them go for $100 either way.
Also, say I ever sell my car, I just include a note in the owner's manual that the taillights require bulbs for a '99 instead of a '98 and the new owner won't have any troubles.
hueman
Mid-Atlantic (Sales)
Oct 19, 2013 11:58 AM
VTECROAR96typeR
Aug 25, 2009 05:13 PM
geebs
19
May 8, 2007 12:16 AM
initialR
Aug 15, 2005 03:00 AM
illmatic_si
Mar 26, 2002 05:44 PM
