hasport mount looks funny for b20 swap
Old May 5, 2007 | 12:10 PM
Galaxy Si's Avatar
Default hasport mount looks funny for b20 swap
i recently purchaced a hasport mout kit for a b20b swap going into my 89' civic hatch. when the driver side mount is on the motor it doesnt line up with the rest of the motor, instead it turns toward the front of the car. the holes line up just that i dont think the motor will when it goes into the bay. do i have a mount for another motor or does this sound right? please help
Modified by Galaxy Si at 1:27 PM 5/5/2007
Old May 5, 2007 | 12:53 PM
Suck my DX's Avatar
Default Re: hasport mount looks funny for b20 swap (Galaxy Si)
pics?
dont judge it by just looking at it without the engine being in the bay...hook up the rear mount first and the other two will line up...
are you sure its not upside down?
did you order the right mount kit?
Old May 5, 2007 | 12:56 PM
HatchMo's Avatar
has your car been wrecked?
Old May 5, 2007 | 01:15 PM
abusedhusband's Avatar
which engine mount bracket is bolted to the block, a b20 or a ls from a 90-91 teg
Old May 5, 2007 | 01:21 PM
Galaxy Si's Avatar
Default Re: hasport mount looks funny for b20 swap (abusedhusband)
1.its not upside down
2. i double checked that i ordered the right parts
3. the engine mount bracket is the original b20b one. i was thinking that the bracket could be wrong
so is that wat u think it is, i need an engine mount braket from 90-93 teg
Old May 5, 2007 | 01:30 PM
HatchMo's Avatar
Yessir, Do you have the correct Rear T-bracket too? I have the Both mounts you need pm me.
Old May 5, 2007 | 02:07 PM
Bob_760's Avatar
Default Re: (HatchMo)
It's because you have the wrong drivers side mount bracket, hasport lists somewhere that you have to use a obd-0 B16A or 90-93 DA Integra type mount bracket.
When you take the timing cover off its 3 bolts (you can see two without removing the cover but there is a third)
Old May 6, 2007 | 12:17 AM
Galaxy Si's Avatar
Default Re: (Bob_760)
thank you very much for everyones help
Old May 9, 2007 | 10:06 AM
ef9vlad's Avatar
you need the mount on the side of the motor off a 90 91 integra ls
existanzcivicb20
Apr 18, 2017 03:12 AM
sebbois
10
Aug 31, 2012 10:09 PM
ridgeapd
Aug 21, 2009 06:21 PM
jaskuloski97sh
Jul 20, 2007 09:30 PM
fkncivic
Oct 23, 2003 11:09 PM
