how much can you boost on pump gas?
Old May 30, 2002 | 03:16 PM
DVSBOOST's Avatar
Default how much can you boost on pump gas?
how high can you boost on pump gas before you start to detonate?
Old May 30, 2002 | 03:18 PM
dustin's Avatar
Default Re: how much can you boost on pump gas? (DVSBOOST)
depends on a bunch of things...
fuel octane
static compression ratio
intercooler efficiency
design of combustion chamber
etc
Old May 30, 2002 | 04:20 PM
fast[R]'s Avatar
Default Re: how much can you boost on pump gas? (dustin)
I have the same question, my set up 9,0,1 JE pistons eagle rods walbro fuel pump 550cc RC injectors STR intake manifold, turbo is a T3/T4, the ic is from drag 2 kit planing to upgrade the ic soon, (STOCK SLEEVES) and to run all this the new AEM ecu, so max boost on 94 octane?
civic-r11
Sep 19, 2011 09:24 AM
purpleh22
Mar 10, 2006 09:12 PM
pkripper94
Apr 28, 2003 11:52 AM
B18C-RnVA
Sep 5, 2001 02:14 PM
