differential fell??
Old May 5, 2007 | 11:18 AM
griz50cal's Avatar
Default differential fell??
I took both the axles out of my 89 crx in order to remove my engine and now i cant get my passenger side axle to go all the way into the transmission. My father tells me my differential may have fell, wen i look into the tranny i see a metal rod behind where the axle goes in. Does it sound liek my differential fell? If so wat can I do to fix it?
Old May 5, 2007 | 11:29 AM
fireant's Avatar
Default Re: differential fell?? (griz50cal)
If you see the metal rod, that's the diff pin. Turn the other axle and it should rotate around... perfectly normal.
Check the snap ring on the axle and make sure its ok, then try again.
Old May 5, 2007 | 11:30 AM
e jay one's Avatar
i really dont think differentials fall in hondas. ive literally thrown trannys around and axles would still go in. you just gota sorta hammer it in cause that spring clip thing on the end.
Old May 5, 2007 | 01:25 PM
abusedhusband's Avatar
make sure its the wright axle and then check the c clip and make sure the open end is facing down and hit it in with a rubber mallet.
Old May 5, 2007 | 02:26 PM
danmdevries's Avatar
Default Re: differential fell?? (abusedhusband)
They can fight you a little bit. The inner cv joint allows for some in-out movement, what I do is extend it so it's full out, slide it in by holding it by the cv joint and then push the axle in with force. Usually that little bit of sliding will pop it right in. Might have to try it a few times. I had an axle fight me for about 15 minutes before it went in.
Be sure you're pushing as straight as possible. Pull your spindle off if you can, it'll give you a nice straightshot.
Old May 5, 2007 | 06:04 PM
rexracerboy's Avatar
Default Re: differential fell?? (danmdevries)
...and don't forget to slap a little hard grease on that ring and try to center it or you will be FOREVER trying to get your axle back in, I learned the hard way.
Old May 5, 2007 | 07:13 PM
griz50cal's Avatar
Default Re: differential fell?? (fireant)
Thx ill try it tomorrow, I just wanna get it in so i can see if the car runs after this rebuild i did.
Old May 5, 2007 | 07:22 PM
enkeiteg's Avatar
griz make sure the axle is PERFECTLY straight in the
trans. the c-clip on the end of the axle shaft is meant to go in with a very snug fit. also use the outer axle and use the momentum to ram in the inside of the axle. like a slide hammer. also kinda twist the axle in the trans to make sure the splines have lined up correctly. hope this helps.
Cap'N Chronic
Jun 29, 2011 12:54 PM
bmxkills
Jan 30, 2011 08:53 PM
david90
Jun 15, 2004 03:33 PM
ghettoracer
Oct 6, 2002 02:18 PM
Aron Parsons
Apr 15, 2002 01:17 PM
