code 14 IACV can't get it to go away
Old May 5, 2007 | 09:32 AM
dad0c402's Avatar
Default code 14 IACV can't get it to go away
So my car threw a code 14 on sunday, tried to fix it the next day, checked the wires and resetted the ecu, still nothing. Bought a used IACV from someone here on honda-tech just stuck that on, still nothing. Voltage reads 13.45 after I let the car idle for awhile till it dropped to around 700. Anything else I should check or do? Any help would be much appreciated.
Old May 5, 2007 | 09:43 AM
pdiggitydogg's Avatar
Clean the connectors (harness mostly) with a small amount of brake cleaner or specific e- connector cleaner, then slap on a glob of dielectric grease
I had the same problem a few years ago - did that and no problems since
Old May 5, 2007 | 10:48 AM
dad0c402's Avatar
Default Re: (pdiggitydogg)
Just did as you suggested and then resetted the ecu again. Started it up and it idled at 300 or a couple of seconds then picked up and the cel came back on. Is there a way to test for a bad iacv?
Old May 5, 2007 | 11:34 AM
1) Measure voltage between ground and the iacv voltage wire with the car in the 'on' position - got voltage?
2) Measure voltage between ground and iacv ecu pin, again in the 'on' position - got voltage?
3) From the ecu, provide connection between ecu ground and iacv pin - the iacv will click if its good (you will need someone to listen while you do that)
ecu pin maps at http://technet.ff-squad.com
Old May 5, 2007 | 08:06 PM
dad0c402's Avatar
thanks for the info, I'll give it a try asap.
mhernandez
Feb 17, 2013 01:52 PM
t3mppa_FIN
Engine Management and Tuning
Oct 20, 2012 06:07 AM
sevenfc
45
Oct 15, 2009 03:52 AM
MWLW20
41
Aug 28, 2009 04:45 PM
guy_from_nerk
12
Jan 13, 2009 07:24 AM
