timing belt?...
Old May 5, 2007 | 06:56 AM
VTECth1s's Avatar
Default timing belt?...
How can I determine if the timing belt on my 91 DA needs to be replaced?
Old May 5, 2007 | 07:16 AM
Sam92Teg's Avatar
Default Re: timing belt?... (VTECth1s)
The timing belt is so vital to the well being of your engine, if you don't know the amount of miles on it, replace it. For immediate consideration, you can visually inspect the belt to see if the ribs have any wear, or if you see any deterioration of the rubber. Problem is, the belt can look fine and still fail if it is near the end of its useful life. It is a good idea to change the water pump and tensioner while your there.
Old May 5, 2007 | 08:04 AM
VTECth1s's Avatar
Default Re: timing belt?... (Sam92Teg)
cool. sounds good! well look into that asap.
Old May 5, 2007 | 08:14 AM
VTECth1s's Avatar
Well I do plan on swapping the motor out anyway, should I really get the timing belt, etc done?, cause I do have another car to drive if anything...hmm?
Comp97GSR
Dec 30, 2022 12:10 PM
adeline
Feb 10, 2011 06:32 PM
chahsiubow
Dec 14, 2007 10:01 PM
honda94accord
Apr 10, 2007 05:39 AM
