VERY small leak in factory steel brake line - what should I do?
Old May 5, 2007 | 12:30 AM
pcguy760's Avatar
Default VERY small leak in factory steel brake line - what should I do?
I just discovered a "pinhole" leak on one of my steel brake lines that go from the proportioning valve to the rear right brake cylinder. The leak is a few inches away from the proportioning valve and if I have someone press on the brakes I can see a very faint stream of brake fluid...
So what should I do? Can I just sandpaper it down and solder the pinhole or do I have to absolutely get a whole new line?
Old May 5, 2007 | 02:06 AM
john666's Avatar
Default Re: VERY small leak in factory steel brake line - what should I do? (pcguy760)
maybe a tiny spot weld ?
Old May 5, 2007 | 02:39 AM
pimpinblackcivic's Avatar
best just to buy a new line...not worth the gamble imo
Old May 5, 2007 | 06:51 AM
ke98248's Avatar
Default Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">best just to buy a new line...not worth the gamble imo</TD></TR></TABLE>
Old May 5, 2007 | 06:58 AM
uneek360's Avatar
The best thing you could ! Why risk having brake failure ( if possible ) and putting your life and other's in danger ?
Old May 5, 2007 | 07:03 AM
Heretic:Si's Avatar
Default Re: (uneek360)
i suggest you replace it...
Old May 5, 2007 | 08:08 AM
del_slow420's Avatar
Default Re: (Heretic:Si)
replace there cheap and u can get them already bent online.. ill find the page i was just looking at brake lines for my sol cause i took out the abs cause it didnt work
heres the site.. hondapartscheap.com
Old May 5, 2007 | 08:15 AM
pcguy760's Avatar
Default Re: (del_slow420)
Thanks everyone! I will get the brand new line then and be done with it - besides its a pain in the butt to work on those brake lines with the H22A IN the car (it's currently out) so I might as well get it done right.
Old May 5, 2007 | 08:17 AM
pcguy760's Avatar
Hey man - majestichonda is cheaper
Old May 5, 2007 | 08:19 AM
c1v1c98's Avatar
Default Re: (pcguy760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">Hey man - majestichonda is cheaper </TD></TR></TABLE>
That is where I get all of my OEM parts. Good service.
Old May 5, 2007 | 10:02 AM
pcguy760's Avatar
Default Re: (c1v1c98)
Hanmin
Aug 6, 2008 02:10 PM
arielmalespin
Mar 28, 2007 03:48 PM
eh2 nihonjin
10
Sep 29, 2003 04:33 AM
jolt-tsp
Aug 27, 2003 05:05 AM
DB2-R81
10
Jun 30, 2003 09:27 PM
