Need some info on swaybars for 92-95ex coupe
Old May 4, 2007 | 11:04 PM
yeegsr's Avatar
Default Need some info on swaybars for 92-95ex coupe
I did a few searches but wasn't able to find info i needd. My car is the 95ex coupe with front oem Swaybar and I believe it doesn't have a back swaybar. I noticed Eibach, Susp techniques, and one or two more brands offer front and back swaybars for a price.
Although my car does not have a back swaybar right now, it is bot-on if i buy rear swaybar for my car? any major modification?
my questions can be a repeat from other threats but I can't help to post it since I can't find in search.
Thanks everyone.
Old May 5, 2007 | 02:23 AM
Cream's Avatar
Default Re: Need some info on swaybars for 92-95ex coupe (yeegsr)
if the car came with swaybars in the front should be in rear also. anyway ST sways will attach to the arms with little or no modification. if you wanna go oem you might have to change out the lca's if yours do not have holes to mount the sway.
Old May 5, 2007 | 02:28 AM
BlueIntegraBoy's Avatar
If you go OEM for the rear, you'll need 94-01 Integra rear LCAs or 92-95 Civic EX sedan rear LCAs. You can also get aftermarket LCAs like Omni that will allow the installment of the rear sway bar. Along with the sway, you need all the hardware like endlinks, bushings, d-brackets, sway brackets (if using any OEM sway except ITR), and miscellaneous bolts.
Now if you plan to install an ITR rear sway bar (mucho fun), you'll need some type of rear subframe reinforcement like ASR or Comptech.
Old May 5, 2007 | 11:08 AM
yeegsr's Avatar
Default Re: Need some info on swaybars for 92-95ex coupe (BlueIntegraBoy)
Thanks to Cream and BlueIntegraBoy for wonderful information
I have no intention of planning to do OEM swaybar for rear or front, both will be relaced with ST or Eibach.
All I'm hoping right now is my exhaust piping near the muffler, hopefully it won't be near the swaybar endlink to cause rattling.
Thanks guys
Old May 6, 2007 | 03:06 PM
Cream's Avatar
no problem, if the exhaust is stock it should be okay
Old May 6, 2007 | 03:14 PM
D16SohcVtec's Avatar
The only 92-95 civics that came with BOTH sway bars that I can think of is the EX SEDAN civic. EX coupes and the SI hatchback only came with the front sway bar. IF you want a b nice budget setup you can try to find the GSR rear sway bar with GSR LCAs like someone mentioned or you could try to find a EX SEDAN and use it's LCA and sway bar.
Old May 6, 2007 | 06:18 PM
yeegsr's Avatar
Default Re: Need some info on swaybars for 92-95ex coupe (D16SohcVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">The only 92-95 civics that came with BOTH sway bars that I can think of is the EX SEDAN civic. EX coupes and the SI hatchback only came with the front sway bar. IF you want a b nice budget setup you can try to find the GSR rear sway bar with GSR LCAs like someone mentioned or you could try to find a EX SEDAN and use it's LCA and sway bar.</TD></TR></TABLE>
I found stock oem parts are hard to find, I can find them but just for time-consuming I'd like to do bolt-on stuffs. : )
Old May 7, 2007 | 10:33 AM
yeegsr's Avatar
Hmm, now I'm wondering if it is worth the money as well as effort to just upgrade the Endlinks and pushings of my stock oem front swaybar. If, I'm not mistaken, the stock swaybar is 21mm for my car
Has anyone done this before?
Angel23
Oct 15, 2011 08:58 AM
JDM Like Whoa
Suspension & Brakes
Sep 29, 2010 05:25 PM
85mm LS VTEC
Jan 29, 2007 12:44 AM
Vantage
Honda Civic (2001 - 2005)
Jul 26, 2006 09:01 PM
viprcr1
Aug 16, 2003 04:58 PM
