Need help ASAP, before I head to the shop in the morning! *pics*
Old May 4, 2007 | 10:58 PM
dc forever guy's Avatar
Default Need help ASAP, before I head to the shop in the morning! *pics*
Ok, yesterday I cleaned the engine bay. So my bro was helping with the degreasing part of the block, well while I'm going to turn on the hose to rinse it off I come back and he has one of the spark plug cables out and is cleaning something. I tell him not to worry about it and he pushes it back in and we go about our business and I hose it off. Well I take it to a dinner and pop the hood to show someone the clean engine bay and a black "substance" has shot from that same plug up onto the underside of the hood, and is leaking a bit around the plug. Well I bark at my bro a bit. Well let me know what you think, here are some pictures.
Modified by dc forever guy at 8:34 AM 5/5/2007
Old May 5, 2007 | 07:03 AM
kleanlscivic's Avatar
Default Re: Need help ASAP, before I head to the shop in the morning! *pics* (dc forever guy)
looks like oil spark plug tube seal went bad or valve cover would be my guess?
Old May 5, 2007 | 07:13 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Need help ASAP, before I head to the shop in the morning! *pics* (kleanlscivic)
LOL, that "black substance" is definately motor oil alec.
It just needs to be pushed all the way down and cleaned out.
Old May 5, 2007 | 08:56 AM
Default Re: Need help ASAP, before I head to the shop in the morning! *pics* (ek forever guy)
Adam dont forget we live in the same house yu dont have to post to tell me something all the time. an yes i know its oil but at 3:30am I touched some smelled it and it didnt smell like oil ok.
Dont forget your the one who didnt push it all the way back down either. (ek forever guy)
But now the car is fixed, I went and bought a new set of spark plug wires.
Old May 5, 2007 | 11:14 AM
Sam92Teg's Avatar
How did the car run, poorly, studdering? I don't think your brother forgot to put the wire on, I think the spark plug is loose or broken and the compression blew the wire off and sprayed that oil onto the cover. The only way for oil to shoot up on your valve cover like that is if you have a worn tube seal leaking oil into the tube and a loose or broken spark plug causing the compression to blow the oil up and out. At least that is what COULD cause that.
How is pushing the spark plug wire on going to prevent oil from being in the plug tube?
Put a socket on that spark plug and see if it is loose or broken and replace your tube seal.
Old May 6, 2007 | 07:22 AM
j12paris's Avatar
Default Re: Need help ASAP, before I head to the shop in the morning! *pics* (Sam92Teg)
Thats not oil, it would have spread out more on the valve cover. (If youve ever seen a vavle cover gasket leak oil, youll know what i mean - the area around it gets darker). It looks like dirty *** water.
TeayotaSoupra
Sep 20, 2005 12:13 PM
GroundZer0
13
Apr 25, 2003 04:42 PM
si91
12
Jun 2, 2002 11:59 PM
Halo
Jul 3, 2001 06:47 PM
