Ls headers on 00 GSR?
Old May 4, 2007 | 08:24 PM
GsrIntegra789's Avatar
Default Ls headers on 00 GSR?
Hey guys ive been searching around but couldent find any good info about putting LS headers on my 00 gsr. I want to go the 4-2-1 route and i found headers off ebay. http://cgi.ebay.com/ebaymotors...ZWD1V
I was wondering if any one knows if those headers will bolt straight up to my stock cat. If anyone has experience with this let me know thanks.
Old May 4, 2007 | 08:46 PM
Default Re: Ls headers on 00 GSR? (GsrIntegra789)
nobody knows?
Old May 4, 2007 | 08:52 PM
Jtuned DC2's Avatar
* B A N N E D *
nah man wont work, heads are differnet
Old May 4, 2007 | 08:54 PM
Default Re: (KevLo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevLo &raquo;</TD></TR><TR><TD CLASS="quote">nah man wont work, heads are differnet</TD></TR></TABLE>
i dont think thats the problem..i know the bolt pattern is the same. I can think of two problems. Either the headers are longer/shorter. Or the flange is on a different angle
Old May 4, 2007 | 09:01 PM
doood's Avatar
been there done that
Default Re: (GsrIntegra789)
the header's are the same length. the flange might be a problem.
Old May 4, 2007 | 09:02 PM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">the header's are the same length. the flange might be a problem.</TD></TR></TABLE>
anyone know for sure?
Old May 4, 2007 | 09:38 PM
crackerjacker006's Avatar
the length of the cat is different on the ls, or either the flange won't line up correctly, so no it will not work without modification.
Old May 4, 2007 | 10:48 PM
Kafelatte's Avatar
in order for you to use the ls headers you will have to shorten your exhaust piping because the ls is longer at the bottom. the bolt pattern are the same with all b-series. not sure if it works but you can try using the omni power adjustable straight pipe if you don't want to cut your exhaust.
Old May 5, 2007 | 02:26 AM
tomithy's Avatar
Default Re: (Kafelatte)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kafelatte &raquo;</TD></TR><TR><TD CLASS="quote">in order for you to use the ls headers you will have to shorten your exhaust piping because the ls is longer at the bottom. the bolt pattern are the same with all b-series. not sure if it works but you can try using the omni power adjustable straight pipe if you don't want to cut your exhaust.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crackerjacker006 &raquo;</TD></TR><TR><TD CLASS="quote">the length of the cat is different on the ls, or either the flange won't line up correctly, so no it will not work without modification.</TD></TR></TABLE>
It should work fine. The bolt pattern is not different. The piping is not different. The length isn't different. 00-01 gs-r is the same as all other 94-01 ls/gs/itr. If you don't know, then don't give out bad info.
I have a header from an itr on my 01 gs-r and it fits fine.
Modified by tomithy at 3:37 AM 5/5/2007
Old May 5, 2007 | 05:56 AM
Padawan's Avatar
Darth ModerVader
Default Re: (tomithy)
There was quite a bit of misinformation posted in this thread.
Tomithy is the only one who is correct. No modification is necessary to install an LS header on a '00 GS-R. They're completely interchangeable.
Old May 5, 2007 | 06:12 AM
jlfrnce's Avatar
Default Re: (Padawan)
i tried putting a dc header from a 00 civic si, and it wouldn't fit 01 gsr, it was also a 4-1.
Old May 5, 2007 | 06:13 AM
Padawan's Avatar
Darth ModerVader
Default Re: (jlfrnce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlfrnce &raquo;</TD></TR><TR><TD CLASS="quote">i tried putting a dc header from a 00 civic si, and it wouldn't fit 01 gsr, it was also a 4-1. </TD></TR></TABLE>
That's because the Si's cat has a flange that is positioned at a different angle. This discussion is about Integra manifolds.
Old May 5, 2007 | 09:09 AM
shadydb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
That's because the Si's cat has a flange that is positioned at a different angle. This discussion is about Integra manifolds. </TD></TR></TABLE>
also remember the SI is a B16 which has a shorter deck height as compared to a B18c..B16 header ng on a B18c but B18c header on B16 is ok..downpipe will hang 10mm lower tho...
Old May 5, 2007 | 09:48 AM
Padawan's Avatar
Darth ModerVader
Default Re: (shadydb7)
That's correct, though it also depends upon how close to the pan a particular manufacturer constructs their header. Certain B16A headers will have sufficient clearance to fit with the B18's roughly 8.9mm taller deck, while others may be too tight. I've never attempted to install a DC that was designed for the B16A onto a B18, so I can't say with certainty how close they build them.
Old May 5, 2007 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">There was quite a bit of misinformation posted in this thread.
Tomithy is the only one who is correct. No modification is necessary to install an LS header on a '00 GS-R. They're completely interchangeable. </TD></TR></TABLE>
That is exactly what i thought. Thank you for clearing that up for everyone. Its nice to see at least two people give out good info
Old May 5, 2007 | 10:56 PM
clem kevin's Avatar
it will work
Old May 6, 2007 | 06:29 AM
Padawan's Avatar
Darth ModerVader
Default Re: (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">
94-99 gsr headers are the shortest of the b-series headers, next is b16, then LS/ITR, but ITR has 2.5" flange</TD></TR></TABLE>
What do you mean by "short"? If we're discussing US-spec manifolds, the only one that is shorter in length from front to back is the '94-'99 GS-R. The B16A is exactly the same length as the LS/ITR and '00-'01 GS-R, and all of them have the same 2.0" OD size collector (the internal diameter differs very slightly).
The JDM ITR header does have a larger 2.5" OD collector, and is indeed slightly longer than the US-spec LS/ITR or '00-'01 GS-R, but the difference in length is only around 1/2" - 3/4".
TheCrimsonGhost666
Mid-Atlantic (Sales)
Nov 18, 2009 11:28 PM
reddc238
Jun 9, 2008 09:14 PM
kahwhy
Jan 18, 2008 11:20 AM
LS stretch
Sep 21, 2003 08:34 PM
BlueIntegraBoy
Jul 28, 2003 09:32 PM
