Right blinker=blown fuse??
Old May 4, 2007 | 07:57 PM
xjustinx's Avatar
Default Right blinker=blown fuse??
Alright, i have a 90 civic si and every time i turn on the right side blinker the signal light fuse blows. When that blows, my entire cluster stops working. I can turn on my lights and i can use my left blinker fine, its just that dang right one. Does anyone have any clue of why this would be??
thanks
Old May 4, 2007 | 10:11 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: Right blinker=blown fuse?? (xjustinx)
Sounds like a short in the wiring for the right turn signal. Have you have either end apart?
Old May 5, 2007 | 12:38 AM
HonDelso's Avatar
yup as stated above me. it MAY be your 2 wires may be melted together. happened to a friend of mines integra. using a high amp fuse may cause this.
Old May 5, 2007 | 05:07 AM
mrcrxtra's Avatar
Default Re: (HonDelso)
http://kalecoauto.com/index.ph..._id=6
Old May 5, 2007 | 10:31 AM
h8tred's Avatar
Default Re: (mrcrxtra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrcrxtra &raquo;</TD></TR><TR><TD CLASS="quote">http://kalecoauto.com/index.ph..._id=6</TD></TR></TABLE>
You know, normally I would find that funny, but there's a time and place. For example if he was asking why his altezzas have moisture in them. Seeing as how that's not the case, you just made yourself out to be a retard with nothing to contribute to this forum, go kill yourself before you reproduce...
Old May 5, 2007 | 10:35 AM
dumped4dr's Avatar
Default Re: (h8tred)
i had the same thing happen to me. and it was a short in the wires due to them melting. im pretty sure when ur cluster lights go out so do ur running lights in the back.
Old May 7, 2007 | 01:56 PM
xjustinx's Avatar
Its been about 4 days since this started happening and now my car wont even start. I guess i might have bumped something while i was looking for bare and melted wires but i have no idea. When i try to start the car it doesnt turn over or anything and the only light on my cluster that turns on is the battery one. This is just getting super frustrating now. Ughhh
Old May 8, 2007 | 10:28 AM
xjustinx's Avatar
Thanks for the input, guys. It turns out that there were bare spots on the 2 blinker wires touching each other. As for the car not starting, it was because the short was draining the battery.
Old May 11, 2007 | 10:58 AM
h8tred's Avatar
Right on, glad you got her figured out.
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
1992acurainteg
Jul 27, 2007 07:40 PM
choua01
Jul 10, 2006 01:18 PM
reallycooleg
Jul 10, 2005 07:20 AM
RiCeRTeG
Mar 16, 2005 04:19 PM
