problem with standalone. i think this is the wrong section, but its a general question and you guys
Old May 4, 2007 | 04:35 PM
Mr.E.G.'s Avatar
Default problem with standalone. i think this is the wrong section, but its a general question and you guys
...are smart
i have a 90 miata that is boosted and has a LINK ecu.
i only ask this in here because i feel that this section contains the best and brightest of honda-tech.
the car is not running right and the issue has been narrowed down to the ecu. with the top cover off of the ecu i can apply pressure to the circuit board an the car works properly. if i relase, the car doesnt run right.
this ecu has a keypad that connect to the ecu which has a read out of my rpms and so forth. when the ecu is running bad, i get a black screen on the keypad. when its running good, the keypad displays properly.
in other words, i poke the ecu board and the screen works/ the car runs right. i relase and the screen goes black/ car will idel but it is incapable of being driven.
i know this is a long shot but what would you say is the cause of this?
surely it has to be a bad solder joint, right? the board flexes and the bad joint touches and works right. the board goes back into normal position and it gets screwy.
doesnt that seem to make sense?
oh, and to keep this post legal for this thread. uhh, can i fabricate something to fix this problem?
i cant find any solder joints that look bad. im at wits end. any advice would be appreciated. thanks.
Modified by Mr.E.G. at 6:44 PM 5/4/2007
Old May 4, 2007 | 07:01 PM
Bailhatch's Avatar
Default Re: problem with standalone. i think this is the wrong section, but its a general question and you g
ya, it could very well be a bad solder joint. I would at least look it over and see if there is anything obvious.
btw- trying flatter a forum into helping you is weird you weirdo
Old May 4, 2007 | 07:04 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">ya, it could very well be a bad solder joint. I would at least look it over and see if there is anything obvious.
btw- trying flatter a forum into helping you is weird you weirdo</TD></TR></TABLE>
hahaha. no flattery. this section is full of some of the best. by nature fabricators think outside of the box to rig stuff up. this is an unusual problem and needs some of that kind of thinking.
Old May 5, 2007 | 01:14 AM
99blusi's Avatar
Sounds like a bad joint...or a broken trace or leg...
Tennis ball and a roll of duct tape should fix it right up
Old May 5, 2007 | 09:44 AM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a bad joint...or a broken trace or leg...
Tennis ball and a roll of duct tape should fix it right up </TD></TR></TABLE>
hahaha. im considering it.
Old May 5, 2007 | 11:01 AM
david@didrace.com's Avatar
We had something similar to this happen with an AEM EMS. Whenever you hit a bump the car would cut out. Tap on the ECU and it would do the same thing. Got it replaced and it's been fine since.
Old May 5, 2007 | 12:59 PM
Mr.E.G.'s Avatar
well, i hope i dont have to replace it. it costs 850 bucks.
Old May 5, 2007 | 07:12 PM
Race Egr's Avatar
If you cant find anything obvious you might take it to your local electronic repair shop. They can usually figure out stuff like that pretty easily
Old May 5, 2007 | 08:41 PM
Mr.E.G.'s Avatar
i'll try that. its just tricky because i am so freaking busy at work. oh, and i dont have a goddamn car that runs.
PRP
Engine Management and Tuning
May 16, 2010 07:25 PM
§95HATCH§
May 16, 2009 07:19 PM
turbogsr181
Jul 21, 2006 10:22 PM
ef_you_again
17
Mar 28, 2005 07:49 PM
Unsung
Mar 1, 2004 05:44 PM
