need suspension advice (tires rubbing)
Old May 4, 2007 | 04:26 PM
jorge59la's Avatar
Default need suspension advice (tires rubbing)
when i make a sharp turn at around 20+mph my tires rub against my car.
im looking into buying the eibach pro damper kit with some sway bars.
Are other pro dampers much better than eibach? koni, tokico, bilstein, edelbrock, kyb...
what sway bars should i get. neuspeed, tanabe, progress, comptech, Suspension Techniques...
installed now:
-drag 17-7.0
-eibach pro kit(cut half a turn on front springs)
-skunk 2 rear lower tie bar
-edelbrock strut tower bar
thanks!
Old May 4, 2007 | 04:42 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: need suspension advice (jorge59la)
you would get quicker, more intelligent, and all around better answers in the suspension form...
edit: i saw you did post it in there
Old May 4, 2007 | 05:33 PM
Dartanian's Avatar
You can't go wrong with Koni Yellows.
To remedy the rubbing problem, you probably need to either roll the front fenders or raise the front up a bit.
Old May 4, 2007 | 06:14 PM
98GSRDC2's Avatar
Default Re: need suspension advice (Dartanian)
Roll the fenders. theres a thread thats very helpful on team-integra for rolling the fenders. I think its under article as a DIY. Go with type r rear sway bar
Old May 4, 2007 | 06:39 PM
jorge59la's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Roll the fenders. theres a thread thats very helpful on team-integra for rolling the fenders. I think its under article as a DIY. Go with type r rear sway bar</TD></TR></TABLE>
thanks. i just looked up the topic on how to roll fenders so im just going to do that.
But i will be upgrading my suspension.
jorge59la
Suspension & Brakes
14
Jun 18, 2007 02:30 PM
scottblade
Feb 8, 2006 07:31 AM
all_stock
Feb 15, 2004 11:44 AM
PEARLWHITE
Apr 15, 2003 07:28 PM
specie
Nov 21, 2002 09:35 AM
