suspension?
Old 02-15-2004, 02:17 AM
all_stock's Avatar
Default suspension?
i have tokico 5 way adj shocks, neuspeed springs, stock front strut bar, and lower tie bar. what would you reccomend i do next? i cant decide.
Old 02-15-2004, 02:33 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: suspension? (all_stock)
your question is kind of vague. what you should get next depends on what you plan on doing with your car ie: daily driving, autocrossing, drag racing, etc. you basically have all the basics as far as suspension goes. maybe upgrade to some better tires or a sway a bar?
Old 02-15-2004, 02:37 AM
Tad
Tad's Avatar
Default Re: suspension? (AzntaggeR)
yeah, what kind of wheels/tires are you using?
that can affect your cars performance more than any suspension mod.
remember, the only part of your car that actually makes contact with the ground
are the tires.
But anyways,
get a rear strut bar, they're super cheap off ebay, and work fine.
a good set of swaybars will do wonders also.
that would also let you turn down your damping a bit, for a smoother ride,
then let the swaybars control your bodyroll.
Old 02-15-2004, 02:55 AM
all_stock's Avatar
Default Re: suspension? (Tad)
what sway bar would you reccomend
Old 02-15-2004, 03:15 AM
Tad
Tad's Avatar
oem 21mm front , and comptech sway/tiebar in the rear(if you can afford it).
Old 02-15-2004, 08:35 AM
Lil Corb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_stock &raquo;</TD></TR><TR><TD CLASS="quote">i have tokico 5 way adj shocks, neuspeed springs, stock front strut bar, and lower tie bar. what would you reccomend i do next? i cant decide.</TD></TR></TABLE>
I would have gotten a rear sway instead of tie bar first. But anyway get a rear swaybar, upper rear strut bar, and maybe a stiffer front strut bar.
Old 02-15-2004, 09:15 AM
RTE117's Avatar
get front and rear upper strut braces, not ebay ones! After that invest in a rear sway-bar and possibly a larger aftermarket front. Also invest in a front lower tie bar OR rear whichever you don't already have.
Old 02-15-2004, 11:28 AM
all_stock's Avatar
Default Re: suspension? (IDriveAHonda)
thanks i was thinking about new lower control arms like the srr one, are those worth the money?
Old 02-15-2004, 11:44 AM
RTE117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_stock &raquo;</TD></TR><TR><TD CLASS="quote">thanks i was thinking about new lower control arms like the srr one, are those worth the money?
they are basically for bling, i think they have holes for aftermarket sways, but overall just for looks.
Digitalis
05-21-2015 09:15 PM
bruinacura
Suspension & Brakes
01-23-2008 11:57 PM
JAYBOOGIEZZ
05-10-2007 10:29 AM
ramz7887
07-19-2003 11:54 AM
96_GSR
06-10-2002 03:32 PM
Quick Reply: suspension?
