89 crx si sunroof problem
Old May 4, 2007 | 04:14 PM
b16a3delsol's Avatar
Default 89 crx si sunroof problem
I just bought a 1989 crx si and opened the sunroof and now it will not close. I believe it is in the switch but i am not positive. Any help will be appreciated.
Old May 4, 2007 | 05:08 PM
Tyson's Avatar
Default Re: 89 crx si sunroof problem (lsdelsol)
yeah its probably just the contacts on the switch need to be cleaned. carefully pry it out and open it up.
you can manually close the sunroof with a hex key under the plug in the headliner near the sunroof motor.
Old May 4, 2007 | 07:02 PM
Default Re: 89 crx si sunroof problem (Tyson)
where exactly is the plug so that i can close it and than try to fix it. Its been raining alot over here.
Old May 4, 2007 | 08:27 PM
Tyson's Avatar
behind the sunroof opening. plastic round plug. pry it off.
Old Jul 5, 2007 | 07:08 PM
VtecVizcaino's Avatar
Well I had a lil of the same problem and all what I did is put an NEW button... IDK if your sunroof is like solid open or if it's this the button.
Old Jul 5, 2007 | 08:45 PM
t.o.m.'s Avatar
after cleaning the terminals if that still doesnt work, check the fuses and wiring.
OCdude31990
Classic Hondas
Jul 21, 2010 05:48 PM
d00d00dumb87
10
Oct 29, 2008 07:05 PM
SkylineGTR
36
Jan 3, 2007 01:53 AM
jdmekrobot
Jul 15, 2006 01:02 PM
