CAR BOGGING!!! getting on my nerves....
Old May 4, 2007 | 03:10 PM
integraracing91's Avatar
Default CAR BOGGING!!! getting on my nerves....
My car is a 94 hatch with a jdm d15b vtec (si) motor in it. (I didn't do the swap but have put roughly 25-30k on it since i've had it)
The car will drive completely normal when i first start it and start driving. Mabye 5-10 mins of driving later, after it has been running and gets warm, it bogs WHENEVER I touch the gas pedal.
I'm not getting a check engine light but I have a GSR cluster in and i may not have hooked it up correctly?
who knows... anyways
What could it be?
how do I check codes?
Is there any way to make the car run in *cold* mode all the time haha
ANY HELP PA-LEASE
TIA
Old May 4, 2007 | 03:11 PM
unknown0001's Avatar
Default Re: CAR BOGGING!!! getting on my nerves.... (integraracing91)
I'd check the fuel filter/spark plugs/spark plug wires
my friend had the same problem and it was a bad wire/plug
Old May 4, 2007 | 03:20 PM
Default Re: CAR BOGGING!!! getting on my nerves.... (Mr.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.R &raquo;</TD></TR><TR><TD CLASS="quote">I'd check the fuel filter/spark plugs/spark plug wires
my friend had the same problem and it was a bad wire/plug </TD></TR></TABLE>
I replaced plugs and it went away, spark plugs are less than a year old but i'll pull'm and check
I recently put a header and new exhaust on and 2 weeks later the problem is back.
My thought is that it could be a bad O2 sensor based on the cold/warm running thing, but i wanted to hear some input before doing anything.
thanks for the quick reply
Old May 4, 2007 | 05:33 PM
Old May 5, 2007 | 07:03 PM
aghhh
Old May 5, 2007 | 07:17 PM
Tzer's Avatar
Change the plugs again. It's only going to cost you 8 - 10 bucks and your time.
I put new plugs in on Jan, 1st and the car began bogging two weeks ago. I changed them and it's all good now.
When I pulled the plugs and inspected them they looked fine. I even got other opinions from people on them and they thought they looked normal.
Hope this helps.
Old May 5, 2007 | 07:44 PM
Danronian's Avatar
Sounds like it could be a bad coil. Check everything ignition related.
I had a crappy MSD external coil setup, and it would bog a lot when the car was warmed up. Went back to OEM setup, no problem at all.
Old May 8, 2007 | 08:50 AM
Default Re: (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it could be a bad coil. Check everything ignition related.
I had a crappy MSD external coil setup, and it would bog a lot when the car was warmed up. Went back to OEM setup, no problem at all.</TD></TR></TABLE>
Went through replacing things yesterday (oil change, spark plugs, cleaned the o2 sensor) and then i replaced the distributer cap and the old one had tons of corrosion on it ... so far with the brand new cap it has been running fine *knocks on wood*
I'll post again if it acts up again .. in which case i'll max out my credit card with parts to finish my lsvtec
Thank's everyone
about:blank
12
Jan 19, 2008 02:13 AM
em1_fox
Oct 28, 2007 12:11 PM
ek4ferrio
Jun 3, 2007 02:59 PM
Ls_V_TurboSi
Feb 2, 2006 08:53 AM
jweezy225
Aug 4, 2004 03:17 PM
