type r oil pump leak
freshly built gsr for boost, i seem to have oil on my timing belt and i think its coming from the pump and the seal is brand new as well as the pump i made sure everthing was good when i installed it...i first noticed it when i thought it was my cam seals but it was my whole timing belt that was wet and i seen come oil laying on the bottom of the oil pump so i new it wasnt my cam seals...can i get some suggestions
How about your crank seal. Take the crank pulley off then remove timing belt and take the timing belt sprocket off and look behind there.
