NEED HELP ASAP
ok so i have a 97 Ek i swapped in a 00 Si B16, i used a 98 Ex wire harness... i did the swap a while ago the only thing i did was not hook up the CKP sensor because i was running a JDM Type R ECU but now i need a smog so im running a p30 ECU and now i need to wire up my Secondary O2 which is no prblem But my CKP sensor the motor has a 2 wire and my harness is a 3 wire how do i hook it up what do i need to splice...? thanks in advance i really need help ASAP...
CKP (Code 4) is in the Dist. If your throwing that your dist. needs a rebuild. CKF (Code 54) is near the oil pump which i believe your talking about. The 3rd wire is a ground. You could match up the wires and be fine.
https://honda-tech.com/zerothread?id=1196153
Not sure if that helps but try using the search button and entering what your looking for...
well thanks ^ but i already know how to wire the O2 sensor im trying to figure out the 2 wire and 3 wire crank postion sensor and he used OBD2b with OBD2b im using an OBD2a wire harness with an OBD2b Block... any one can help
Take your plug from your old engine, cut the plug from the new engine, put the 2 wires that go in the same location (minus middle dont use) and connect it all together, seriously not hard. Yes very long on i know
