maintenance required?
Old May 4, 2007 | 11:10 AM
diewnaylomoah's Avatar
Default maintenance required?
hey my maintenance required light just turned red yesterday. does that mean i need a maintenace check?
Old May 4, 2007 | 11:15 AM
pdiggitydogg's Avatar
It works like an odometer, spinning around with your miles
As long as you are up to date with oil and other general things, youre probably fine. If youre at like 100k and have never changed the water pump/timing belt, you may want to consider that.
Otherwise, just stick youre key in the reset slot and it will turn green again
Old May 4, 2007 | 11:18 AM
ohh ok. where is the reset clock? yea i just hit 90k
Old May 4, 2007 | 11:19 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (diewnaylomoah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewnaylomoah &raquo;</TD></TR><TR><TD CLASS="quote">ohh ok. where is the reset clock? yea i just hit 90k</TD></TR></TABLE>
it's a button embedded in your cluster that has a half moon shape on the end justting through the clear plastic.
Take your key and hit it.
Old May 4, 2007 | 11:21 AM
is it on the left, right or middle?
Old May 4, 2007 | 11:22 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewnaylomoah &raquo;</TD></TR><TR><TD CLASS="quote">is it on the left, right or middle?</TD></TR></TABLE>
Go look at your ******* cluster. There's only two buttons on it. One is rectangular and concave, the other is a ******* stick.
<FONT SIZE="6">PUSH THE ONE THAT'S NOT A STICK</FONT>
Welcome to Honda-Tech, your hand has been held for the last time.
Are you serious....you cant use your eyes and look at the cluster to figure that out?
I know where....but Im not answering that question because its just retarded.
Old May 4, 2007 | 11:24 AM
Ek Forever y0!
Default Re: (pdiggitydogg)
Word, tired of holding OP's hand.
Old May 4, 2007 | 11:27 AM
Rainy City's Avatar
Default Re: (ek forever guy)
how many buttons are there on the freaking cluster?
Old May 4, 2007 | 11:47 AM
12 or so....apparently
Old May 4, 2007 | 01:05 PM
Agent_EM1's Avatar
LMAO... wow... this guy...
HondaTypeR001
Aug 13, 2008 11:40 AM
mikey-ej7
Jun 22, 2006 10:02 AM
Demon_Dub
Sep 20, 2005 08:35 PM
rocweila
12
Aug 15, 2005 08:56 PM
Mikizzle
Oct 20, 2003 11:43 PM
