Door window help???
Old May 4, 2007 | 09:23 AM
tapuout's Avatar
Default Door window help???
My 91 rex has a problem with the drivers side door window....when I roll it down it rolls down un evenly......towards the front of the car it slopes down more than the back end of the window....has anyone else had this problem and can anyone give me a detailed description on how to fix this....Thanks guys!
Old May 4, 2007 | 11:28 AM
91ed9's Avatar
Default Re: Door window help??? (tapuout)
take of the panel and make sure the track bolts are tight
also there are guides on the side that look like tracks (there blakc) check to make sure all your bolts are there
if they are your regulator might be bad
is it manual or power windows?
Old May 4, 2007 | 11:30 AM
CRX Toad's Avatar
To add to what was said above. Make sure your moldings are not pinching at the top. Sometimes too all they needs is a little lube in the moldling tracks.
Old May 6, 2007 | 01:58 AM
tapuout's Avatar
Default Re: Door window help??? (CRX Toad)
91ed ....it's a 91 crxsi......it has the manual windows..no power windows....I'll try out what you guys said....thanks for your help...this sight is awesome!
Thanks!
Old May 6, 2007 | 02:59 AM
danb18c's Avatar
Default Re: Door window help??? (91ed9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">take of the panel and make sure the track bolts are tight
is it manual or power windows?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">To add to what was said above. Make sure your moldings are not pinching at the top. Sometimes too all they needs is a little lube in the moldling tracks. </TD></TR></TABLE>
it fixed my friends when my friends did the same thing
Tomas P
Apr 6, 2012 12:06 AM
SPOONfed-Rex
Nov 26, 2007 06:24 PM
5lugSlug
12
Mar 5, 2006 03:35 PM
ImprtTuner88
Mar 16, 2005 08:33 PM
96 Accord Ex V6
Jan 11, 2002 02:19 PM
