need help changing front axel!!! PLZ!!
does anyone know of any info on step-by-step to changing the front axel?? online or if you know how and you can help me?? any help will be appreciated!! thanks!
-benie
-benie
Jack it up. Pull off wheels. Undo the axle nut (32 mm - might require impact wrench). Take cotter key out on tie rod end. Take off tie rod nut. Undo through-bolt on the bottom of the fork. Pull the knuckle assembly away and hammer the axle end through the hub. Then just get a prybar and wedge it in between the axle and the tranny. Pop that bad dog out and then you're ready to put the new one in. If some tranny fluid leaks out, that's all right. Stick a rag in the hole if you're not ready to immediately put the new one in. Line up the axle and hammer it into place. Installation is the opposite of removal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benie »</TD></TR><TR><TD CLASS="quote">does anyone know of any info on step-by-step to changing the front axel?? online or if you know how and you can help me?? any help will be appreciated!! thanks!
-benie</TD></TR></TABLE>
Here you go...pictures and everything
https://honda-tech.com/zerothread?id=382416
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
The guy who did that axle article is a douche.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
The guy who did that axle article is a douche.</TD></TR></TABLE>
Thats what i heard
just kidding...nice write up i have used it many times for this same question!
Thats what i heard
one more question, if my alignment is not good, cuz my steering wheel have to be turned slightly to the right to drive straight, can i still change my axle, of course i'll take it to alighnment after i change it..also, should i jack just the side that needs to be fix, or jack both sided of the car up??or does it not matter? thanks for the replies guys, very helpful..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benie »</TD></TR><TR><TD CLASS="quote">one more question, if my alignment is not good, cuz my steering wheel have to be turned slightly to the right to drive straight, can i still change my axle, of course i'll take it to alighnment after i change it..also, should i jack just the side that needs to be fix, or jack both sided of the car up??or does it not matter? thanks for the replies guys, very helpful..</TD></TR></TABLE>
You should be fine to change the axle without being aligned. Just make sure to get an alignment after. You can do one side at a time. You don't have to jack up both sides.
Randysi
13
Jun 29, 2011 07:58 PM
rhdekhatchie
Mar 16, 2008 10:17 PM
crx18c1
10
Apr 17, 2007 10:17 PM
