Help with swap into del sol....I SEARCHED
Old May 4, 2007 | 01:57 AM
Itzmy91Teg's Avatar
Default Help with swap into del sol....I SEARCHED
Car is an AUTOMATIC 94 del sol. I'm in the middle of swapping in a 5-speed b18b1 and i notice the pass. side upper tranny mount wont line up. Anyone else have any problems with this? Just a matter of drilling out the spot welds, moving the mount over and welding it back up? Or do i just need to put in a little extra push and get the mounts to line up?
Any help is greatly appreciated. I searched in both the recent and archived topics and non of them have covered this...
Again for you all
1994 Automatic del sol
Swapping 5-speed b18b1 with DC integra motor mounts
Tranny side upper mount doesn't line up. Move the mount or push the motor back?
Old May 4, 2007 | 02:04 AM
BlueIntegraBoy's Avatar
Default Re: Help with swap into del sol....I SEARCHED (Itzmy91Teg)
It's because the tranny bracket is different between automatic and manual cars. You need an auto to manual mount.
http://www.innovativemounts.co...49520
http://www.innovativemounts.co...40121
http://hasport.com/shop/produc...d=115
Old May 4, 2007 | 06:13 PM
Itzmy91Teg's Avatar
or i can drill it out and move it over and just use regular 5-speed mounts correct?
Old May 4, 2007 | 06:24 PM
hatchi's Avatar
Default Re: (Itzmy91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itzmy91Teg &raquo;</TD></TR><TR><TD CLASS="quote">or i can drill it out and move it over and just use regular 5-speed mounts correct?</TD></TR></TABLE>
Yes you can drill it out and move it then weld back on so you can use the stock 5 spd mount.
Old May 4, 2007 | 08:32 PM
Itzmy91Teg's Avatar
Default Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you can drill it out and move it then weld back on so you can use the stock 5 spd mount. </TD></TR></TABLE>
thank you that was the answer i was lookin for. a simple yes or no
nnac7270
Jun 13, 2016 10:09 AM
Draiga1988
18
Oct 23, 2010 10:49 AM
acidburn2k2
Aug 23, 2008 08:38 AM
JediKnight4life
Jun 24, 2008 12:28 PM
b16delsolnewb
Apr 17, 2008 11:48 AM
