Help! driver side rim has brake dust, passenger side doesnt?
Old May 4, 2007 | 01:20 AM
inspireAZN's Avatar
Default Help! driver side rim has brake dust, passenger side doesnt?
Well like when I wash my car, the only rim that I have to scrub is the driver side one. The passenger side one is like...spotless basically. The driver side one has less tread than the passenger side tire though cause it popped before and I had it replaced....other than that...is something wrong? does that mean my passenger side brake isnt fully functioning? or what oh god
sorry if it sounds confusing o_o
Old May 4, 2007 | 02:01 AM
inspireAZN's Avatar
bump o.o
Old May 4, 2007 | 06:39 AM
97Ej6mike's Avatar
Take your car to a brakeshop, and let them bleed the brakes for you.
-Or-
This is probably not the case, but if two different styles of brake pads were used, assuming one side had to be replace for some odd reason, that would explain allot.
Old May 4, 2007 | 09:45 AM
MJ0LNIR's Avatar
Default Re: Help! driver side rim has brake dust, passenger side doesnt? (inspireAZN)
Check for a seized caliper. This could wear out your left tire much more quickly.
Old May 4, 2007 | 10:14 AM
Greenie's Avatar
Default Re: Help! driver side rim has brake dust, passenger side doesnt? (dr92cx)
Does your car pull real bad to one side when you hit the brakes? Sounds like a stuck caliper.
Old May 4, 2007 | 10:16 AM
deadline's Avatar
bleed the system
TurboEM1
Jul 1, 2007 04:33 PM
Voodooboy520
13
Jan 14, 2007 07:00 AM
98ITR75
Oct 15, 2001 04:22 AM
