MOMO Tuner w/ NRG Quick Release - Slanted Wheel?
Old May 3, 2007 | 06:26 PM
a1320addict's Avatar
Default MOMO Tuner w/ NRG Quick Release - Slanted Wheel?
Just installed my Momo Tuner wheel and NRG Quick release, and the wheel is not straight when driving in a straight line. I have about a 5-10º slant to the left.
I know a lot of you guys do the Momo wheel, wanted to see if anyone knew how to realign the steering wheel?
The car was just aligned and cornerweighted for the season, so the car is aligned, it must be the positioning of the wheel.
I can't seem to get it on the right spline, because the key only allows the wheel to be installed one of two ways.
TIA
Old May 3, 2007 | 06:45 PM
waddy41's Avatar
i had the same problem...was like 3 degrees off
i juss ignored it...
Old May 3, 2007 | 06:48 PM
Default Re: (waddy41)
Hard to get a good grip on the wheel with all the wheel spin
Old May 3, 2007 | 11:10 PM
Bart-EK's Avatar
either you need to take it off and put it back on, turning it one ... uhm... what's the name of it... the lines on the steering column that keep the wheel straight on there...
it's either that, or get an alignment (basically, loosen both steering endlinks while the wheels are straight, make sure everything lines up and fasten the endlinks again... then the steering wheel should be on correctly)
Old May 4, 2007 | 02:33 AM
infulleffect's Avatar
Default Re: (Bart-EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bart-EK &raquo;</TD></TR><TR><TD CLASS="quote">either you need to take it off and put it back on, turning it one ... uhm... what's the name of it... the lines on the steering column that keep the wheel straight on there...</TD></TR></TABLE>
*splines
Old May 4, 2007 | 02:56 AM
oldschoolflava's Avatar
I had to move mine around on the spline until the wheel would line up. NRG can suck my ***
p0gi_b0i_integra
Sep 30, 2007 08:55 AM
Diversion
Aug 27, 2006 02:16 AM
Civicracer17
Mar 18, 2006 12:58 PM
A Blue Lude
Nov 1, 2005 11:45 AM
Bumnah
36
May 10, 2003 06:28 AM
