BserieskllR's new project thread lots of pics! 4dr. YO!
Old May 3, 2007 | 06:06 PM
Bserieskllr's Avatar
Default BserieskllR's new project thread lots of pics! 4dr. YO!
Ok i let my old project thread die down cause i made some changes in my setup so lets start over!
Here is my 91 4dr when i bought it for $700.....my orignal intentions were just to have a clean daily driver cause i got in a little trouble with my old crx but you know how that works...
so i had some kyb struts and ebay coilovers(big mistake) also a set off knock off mugen rnr's threw them on the day after i owned the car. looked clean but rode like crap
then i threw in some si hatch seats and an lx cluster with tach.
also polished the dull paint up
here was my boring power plant
then this happened and i let the car sit for a year cause i lost interest for a bit.
then finally got off my a$$ and picked this d16y7 with 40k miles for $200
got rid of the wheels and got rid of the horid ebay suspension and picked up some tein basics
removed my a/c cause it didnt work the ghetto intake is cause my other one was grounding out alot.
then i picked up some ls mesh's and got a set of nitto neo gen's for them, great tire imo and some recent shots
then i ran over an already dead possum and this is what it left behind gross haha
ok now on to the good stuff here are all the parts ive got waiting to be put on(going boost!)
headgasket set for when i put in the arp head studs
87 yugo radiator, its a half size rad. that is about a half inch shorter then the stock ef radiator but there not to easy to come by also a slim fan, and i had the inlet and outlet rewelded on the radiator
oil line kit
guages and pod
battery relocation kit
intercooler with reducers and t bolts
camgear catch can and heat wrap
just a shot of one of the charge pipes, coupler and tbolt clamp i have a bunch more obviously
exstended lug studs new hood latch cable mine broke and the plastic peices that goes between my hood and filler peice
peices to build my log manifold
my garrett t25 or t28 turbo?? it was free and in good condition
my super solid motor mounts filled with polyurethane and then painted wrinkle black these things have been curing for 5 years haha.
and some headstuds
i also have a new walbro 255 pump, clutchnet 4 puck sprung clutch with yellow pressure plate, traction bars should be here any day now will be ordering a hurst short shifter and wideband next week, and ill be chipped running turbo edit.
the teardown will start may 15th when i start my vacation from work, i took a whole month off for this even though it should be done sooner, also gonna do a wiretuck and all that good stuff and be adding an si tranny so stay tuned for updates
Old May 3, 2007 | 06:10 PM
EJ1 wilcox's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (Bserieskllr)
Looks great
My EF started the same way... as a daily.
Then I swapped a d16z6 in and converted it to OBD1 with some suspension goodies, then I had to boost it.
Good luck with the boost project!
Old May 3, 2007 | 06:32 PM
JKGONZALEZ3's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (EJ1 wilcox)
good to see that your back with the four door.
Old May 3, 2007 | 06:45 PM
garageEF's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (JKGONZALEZ3)
Rep the 4doors
why does the car look "orangy" in the pics with the fake RNR's?
nice start to a solid project!
Old May 3, 2007 | 07:06 PM
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">Rep the 4doors
nice start to a solid project!</TD></TR></TABLE>
because it was a different camera and before i polished the paint.
Old May 3, 2007 | 08:28 PM
My_EFsedan's Avatar
how did u mount the orginal seat belt system on those SIs? i have mint SIs in mines too but i dont know how to mount the seat belt system on there. so im a racing harness right now..
overall nice built, i wanna see some more progress pix!!
Old May 3, 2007 | 09:07 PM
misha's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (My_EFsedan)
looking good! i like the way car looked with those first wheels, even tho they were fake.
But yea like the d-series turbo, good job man!
Will be keeping an eye on this one
Old May 3, 2007 | 10:06 PM
Under Con. CrX's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (misha)
with those seats you deff. have to do the dash swap looks sooooooo much better if do decide to do it make sure you swap out the dash harrness cus its a bit differant and wont plug in to the the plug above your fuse box cus it has 2 more wire than the sedan and the plug is bigger if you do decide to dothis let me know if you need any help over the interweb
Old May 4, 2007 | 09:22 AM
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (Under Con. CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">how did u mount the orginal seat belt system on those SIs? i have mint SIs in mines too but i dont know how to mount the seat belt system on there. so im a racing harness right now..
overall nice built, i wanna see some more progress pix!!</TD></TR></TABLE>
i just took the stock seat rails with all the old seat belt stuff and they bolted right on to the si seats pretty easy, big progress will be in a week and a half when my vacation starts, right now ill just update when i get new goodies in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">with those seats you deff. have to do the dash swap looks sooooooo much better if do decide to do it make sure you swap out the dash harrness cus its a bit differant and wont plug in to the the plug above your fuse box cus it has 2 more wire than the sedan and the plug is bigger if you do decide to dothis let me know if you need any help over the interweb </TD></TR></TABLE>
yea i just have to come across a complete dash and then the fun will start with that!
The reason i got rid of the old fake wheels cause one of them was bent and a friend of mine bought a crx from me and wanted them with the car so off they went. eventually i would like some circuit 8's
Old May 4, 2007 | 10:28 AM
Rhythmsnewsn's Avatar
sweet build! but how do the basics ride? im looking for a full coilover soon and im undecided on what to get.
bump for this thread!
Old May 4, 2007 | 12:19 PM
team-savage's Avatar
sweet build man you've done good so far keep i tup
Old May 4, 2007 | 12:30 PM
mahatma's Avatar
Default Re: (team-savage)
****** sweet!
i chuckled out loud at your possum guts & motor mount comment
Old May 4, 2007 | 01:07 PM
4doorcivic16's Avatar
good work&gt;
Old May 4, 2007 | 04:49 PM
Honda-Hooligan's Avatar
IN FOR A 4 DOOR
Old May 4, 2007 | 05:41 PM
SlobberGoat's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (Honda-Hooligan)
nice 4g4d
Old May 4, 2007 | 06:13 PM
EFM_ookie's Avatar
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (SlobberGoat)
looking good i wish i could find a clean 4 door
Old May 4, 2007 | 10:10 PM
Default Re: BserieskllR's new project thread lots of pics! 4dr. YO! (Rhythmsnewsn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythmsnewsn &raquo;</TD></TR><TR><TD CLASS="quote">sweet build! but how do the basics ride? im looking for a full coilover soon and im undecided on what to get.
bump for this thread! </TD></TR></TABLE>
oh man like a dream ride so nice for a daily driver and where i have them set at to tein
i actually called in to work haha and got alot of work done today updates in a minute got to upload the pics.
Old May 4, 2007 | 10:26 PM
UPDATE!!!!
ok well like i said i called into work sick but i really wasnt so i could get some work done to the car
got my traction bars and clutch today so i decided to put in my traction bars, half rad and slim fan also i put in my new hood release cable and the plastic peice that goes between my hood and filler peice on to the good stuf
gen 3 etd racing traction bars, very nice very nice
old crossmember out, ive always hated these big *** cross members in the ef/ed cars and could not wait to get rid of it.
pictures of my clutch net 4 puck clutch
all the **** i pulled out
traction bars in
getting the 87 yugo radiator in, dont mind my zipties i forgot my mounting bracets for the slim fan at home
my custom overflow tank mounting, i actually used a bracet from the windsheild washer tank to mount it haha pretty sweet
just some shots
i hate my intake!!!!!!!
had to fab up some radiator mounting brackets
before
after!!!!!
much better
well thats it for now when i take the motor out im gonna clean everything up like give the radiator a nice coat of black and get rid of the zip ties. thanks for all the positive comments guys oh and i also had to mod my hood a bit casue the rad. cap was hitting the webbing but thats it and it fits in there better then the eg radiator and its dual core
more to come
Old May 5, 2007 | 12:21 AM
look good that clutch is going to put some power to the ground
good luck with every thing looking real good
Old May 5, 2007 | 07:36 AM
thanks....bump
Old May 5, 2007 | 08:05 AM
dr_latino999's Avatar
Default Re: (Bserieskllr)
Ok, just for the record I'm still the O.G. for Sedan's in Florida (well not really but I call dibs ). Since you're not running a front mount, how are you countering engine movement?
Old May 5, 2007 | 08:08 AM
SIred91's Avatar
Rainman
Sawizzeet......
Old May 5, 2007 | 08:51 AM
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, just for the record I'm still the O.G. for Sedan's in Florida (well not really but I call dibs ). Since you're not running a front mount, how are you countering engine movement?</TD></TR></TABLE>
haha, right now im just running the 3 mounts, 2 of them have inserts, i will be installing the super solid mounts in the first post in so im sure there wont be a problem with any movement, right now its not reall that bad it just feels like when i had all 4 mounts without any inserts.
Old May 5, 2007 | 09:25 AM
misha's Avatar
sorry, i think i missed it, what rad is it again? By the way looks pretty good
Old May 5, 2007 | 09:55 AM
rhd_ef8's Avatar
Default Re: (misha)
lookin good, keep it up
